* | arm: Fix ARMv7-M interrupt processing | Sebastian Huber | 2017-07-04 | 1 | -19/+31 |
| | | | | | | | | | | | | Right after a "msr basepri_max, %[basepri]" instruction an interrupt service may still take place (observed at least on Cortex-M7). However, pendable service calls that are activated during this interrupt service may be delayed until interrupts are enable again. The _ARMV7M_Pendable_service_call() did not check that a thread dispatch is allowed. Move this test from _ARMV7M_Interrupt_service_leave() to _ARMV7M_Pendable_service_call(). Update #3060. | ||||
* | arm: Add support for FPv4-SP floating point unit | Sebastian Huber | 2014-08-12 | 1 | -5/+25 |
| | | | | | This floating point unit is available in Cortex-M4 processors and defined by ARMv7-M. This adds basic support for other VFP-D16 variants. | ||||
* | arm: Include <rtems/score/cpu.h> | Sebastian Huber | 2013-01-07 | 1 | -2/+1 |
* | score misc: Clean up Doxygen #13 (GCI 2012) | Mathew Kallada | 2012-12-02 | 1 | -0/+6 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8013205 | ||||
* | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-24 | 1 | -0/+65 |
* rtems/score/armv7m.h, armv7m-context-initialize.c, armv7m-context-restore.c, armv7m-context-switch.c, armv7m-exception-handler-get.c, armv7m-exception-handler-set.c, armv7m-exception-priority-get.c, armv7m-exception-priority-set.c, armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c, armv7m-isr-level-get.c, armv7m-isr-level-set.c, armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. * rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S: Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. |
