path: root/cpukit/score/cpu/arm/armv7m-exception-priority-set.c (follow)
* arm: Include <rtems/score/cpu.h>Sebastian Huber2013-01-071-3/+1
* score misc: Clean up Doxygen GCI Task #12Alex Ivanov2012-12-071-0/+6
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/7983217
* ARMv7-M NVIC and MPU API changes.Sebastian Huber2012-02-111-3/+3
* 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2011-09-241-0/+34
* rtems/score/armv7m.h, armv7m-context-initialize.c, armv7m-context-restore.c, armv7m-context-switch.c, armv7m-exception-handler-get.c, armv7m-exception-handler-set.c, armv7m-exception-priority-get.c, armv7m-exception-priority-set.c, armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c, armv7m-isr-level-get.c, armv7m-isr-level-set.c, armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. * rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S: Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M.
