* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | arm: Include <rtems/score/cpu.h> | Sebastian Huber | 2013-01-07 | 1 | -3/+1 |
* | score misc: Clean up Doxygen #13 (GCI 2012) | Mathew Kallada | 2012-12-02 | 1 | -0/+6 |
| | | | | | | | This patch is a task from GCI 2012 which improves the Doxygen comments in the RTEMS source. http://www.google-melange.com/gci/task/view/google/gci2012/8013205 | ||||
* | arm: New function | Sebastian Huber | 2012-04-07 | 1 | -0/+35 |
Add and use function _ARMV7M_Set_exception_priority_and_handler(). Use ARMV7M_EXCEPTION_PRIORITY_LOWEST define. |
