* | score: Add ARM CPU architecture group | Sebastian Huber | 2019-03-26 | 1 | -1/+1 |
| | | | | Update #3706. | ||||
* | score: Rename ScoreCPU Doxygen group | Sebastian Huber | 2019-03-26 | 1 | -1/+1 |
* | Remove superfluous <rtems/system.h> includes | Sebastian Huber | 2019-03-14 | 1 | -1/+0 |
* | arm: Add and use _ARM_Exception_default() | Sebastian Huber | 2013-01-07 | 1 | -4/+3 |
* | arm: Change CPU_Exception_frame | Sebastian Huber | 2013-01-07 | 1 | -8/+10 |
| | | | | | Provide proper CPU_Exception_frame definition for ARMv4 and use it. Remove arm_cpu_context. | ||||
* | arm: Rename type and functions | Sebastian Huber | 2013-01-07 | 1 | -8/+8 |
| | | | | | | | | | | Rename arm_exc_abort_handler to ARMV4_Exception_abort_handler, arm_exc_data_abort() to _ARMV4_Exception_data_abort(), arm_exc_data_abort_set_handler() to _ARMV4_Exception_data_abort_set_handler(), arm_exc_prefetch_abort() to _ARMV4_Exception_prefetch_abort(), and arm_exc_prefetch_abort_set_handler() to _ARMV4_Exception_prefetch_abort_set_handler(), | ||||
* | 2011-09-24 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-09-24 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | * rtems/score/armv7m.h, armv7m-context-initialize.c, armv7m-context-restore.c, armv7m-context-switch.c, armv7m-exception-handler-get.c, armv7m-exception-handler-set.c, armv7m-exception-priority-get.c, armv7m-exception-priority-set.c, armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c, armv7m-isr-level-get.c, armv7m-isr-level-set.c, armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New files. * Makefile.am, preinstall.am: Reflect changes above. * rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. * rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S: Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M. | ||||
* | 2010-11-23 Gedare Bloom <giddyup44@yahoo.com> | Sebastian Huber | 2010-11-23 | 1 | -1/+9 |
| | | | | | PR 1719/cpukit * arm_exc_abort.S: Avoid "bx" instruction to support ARMv4 and below. | ||||
* | add/adapt documentation | Thomas Doerfler | 2010-04-08 | 1 | -1/+1 |
* | 2010-04-07 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-07 | 1 | -1/+1 |
| | | | | * arm_exc_abort.S: Fix warnings about TRUE/FALSE not defined. | ||||
* | 2010-03-27 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-03-27 | 1 | -0/+4 |
| | | | | | * arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S, cpu.c, cpu_asm.S: Add include of config.h | ||||
* | add support for lpc32xx | Thomas Doerfler | 2010-01-12 | 1 | -0/+123 |
