* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | arm: Use ARM code on Thumb 1 targets | Sebastian Huber | 2017-08-10 | 1 | -1/+1 |
| | | | | Update #3093. | ||||
* | arm: Validate IT[7:0] bit field of PSR | Sebastian Huber | 2017-08-10 | 1 | -1/+25 |
* | arm: Fix CPU context validation for Cortex-R4 | Sebastian Huber | 2017-03-09 | 1 | -5/+1 |
| | | | | Do not touch the FPSCR[QC] bit since this is DNM/RAZ on Cortex-R4. | ||||
* | arm: Add VFP context validate support for ARMv5 | Kevin Kirspel | 2016-08-19 | 1 | -3/+6 |
* | arm: Add support for FPv4-SP floating point unit | Sebastian Huber | 2014-08-12 | 1 | -12/+19 |
| | | | | | This floating point unit is available in Cortex-M4 processors and defined by ARMv7-M. This adds basic support for other VFP-D16 variants. | ||||
* | arm: Support VFP-D32 and Neon | Sebastian Huber | 2013-05-10 | 1 | -1/+159 |
* | score: Add CPU context validation | Sebastian Huber | 2013-05-10 | 1 | -0/+139 |
