PR 1965/cpukit
* rtems/score/arm.h: Select ARMv4 multilib implementation for
__ARM_ARCH_7A__.
* rtems/score/cpu.h: Removed unused register_pc from Context_Control.
PR 1949/cpukit
PR 1950/cpukit
__ARM_ARCH_6J__.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* rtems/score/armv7m.h, armv7m-context-initialize.c,
armv7m-context-restore.c, armv7m-context-switch.c,
armv7m-exception-handler-get.c, armv7m-exception-handler-set.c,
armv7m-exception-priority-get.c, armv7m-exception-priority-set.c,
armv7m-initialize.c, armv7m-isr-dispatch.c, armv7m-isr-enter-leave.c,
armv7m-isr-level-get.c, armv7m-isr-level-set.c,
armv7m-isr-vector-install.c, armv7m-multitasking-start-stop.c: New
files.
* Makefile.am, preinstall.am: Reflect changes above.
* rtems/score/arm.h: Define ARM_MULTILIB_ARCH_V4 and
ARM_MULTILIB_ARCH_V7M.
* rtems/score/cpu.h, cpu_asm.S, cpu.c, arm_exc_abort.S,
arm_exc_handler_high.c, arm_exc_handler_low.S, arm_exc_interrupt.S:
Define CPU_HAS_HARDWARE_INTERRUPT_STACK to FALSE. Use
ARM_MULTILIB_ARCH_V4 and ARM_MULTILIB_ARCH_V7M.
* rtems/score/arm.h: More CPU_MODEL_NAME variants.
* Makefile.am: Reformat.
PR 1780/cpukit
* rtems/score/cpu.h: Lower alignment requirements for
CPU_PARTITION_ALIGNMENT according to AAPCS.
* cpu.c, rtems/score/cpu.h:
PR 1719/cpukit
* arm_exc_abort.S: Avoid "bx" instruction to support ARMv4 and below.
* rtems/score/cpu.h: Set alignment requirements according to AAPCS.
PR 1635/cpukit
* rtems/score/types.h: Refactoring of priority handling, to isolate the
bitmap implementation of priorities in the supercore so that priority
management is a little more modular. This change is in anticipation
of scheduler implementations that can select how they manage tracking
priority levels / finding the highest priority ready task. Note that
most of the changes here are simple renaming, to clarify the use of
the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
* rtems/score/cpu.h: Removed CPU_ENABLE_C_ISR_DISPATCH_IMPLEMENTATION
define.
PR 1573/cpukit
* arm_exc_interrupt.S: Add a per cpu data structure which contains the
information required by RTEMS for each CPU core. This encapsulates
information such as thread executing, heir, idle and dispatch needed.
* rtems/score/arm.h: Make it a warning not error that the FPU multilib
is not supported yet.
* arm_exc_abort.S: Fix warnings about TRUE/FALSE not defined.
* arm_exc_abort.S, arm_exc_handler_high.c, arm_exc_handler_low.S,
arm_exc_interrupt.S, cpu.c, cpu_asm.S: Add include of config.h
* rtems/score/arm.h: Recognize ARMv7A.
* rtems/score/arm.h: Recognize ARMv6J as needed by arm1136 variants.
* rtems/asm.h: Added macro to define ARM functions.
* cpu_asm.S, arm_exc_handler_low.S: Use macro from above.
* rtems/score/cpu.h: Mark _CPU_Context_restore() as noreturn so the
compiler will not generate code thinking it returns.
* rtems/score/cpu.h: Remove warnings.
* cpu.c, rtems/score/cpu.h: Eliminate _CPU_Thread_dispatch_pointer and
passing address of _Thread_Dispatch to _CPU_Initialize. Clean up
comments.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* cpu.c: Remove extraneous spaces.
* Makefile.am: Merge thumb/Makefile.am.
* thumb/Makefile.am: Remove (superfluous).
* cpu.c, rtems/score/cpu.h: Convert to "bool".
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* cpu.c, rtems/score/cpu.h: Add void.
* cpu.c: Add comment.
* cpu.c: Add arm_cpu_mode so ARM BSP can overrid default value for
cpsr.
* rtems/score/cpu.h: Add _CPU_Context_Get_SP() for stack check utility.
* rtems/score/cpu_asm.h: Sweep to make sure grep for COPYRIGHT passes.
* rtems/score/cpu.h: Temporarily use C implementation of swap u32 for
thumb mode.
* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* rtems/score/cpu.h: Do not inline _Thread_Enable_dispatch for Thumb to
save space.
* cpu.c, score/cpu.h: Fix headers. Remove extra inline definition.
* cpu_asm.S: Note origin of Thumb support.
* cpu.c: Fix headers.
* cpu.c, cpu_asm.S, score/cpu.h : add support for ARM<->THUMB veneer
thumb new dir to controll CPSR/SPRS in thumb mode
2007-05-09 Ray Xu <rayx.cn@gmail.com>
* cpu.c: move do_data_abort() to libbsp/arm/shared/abort/
implement a compact do_data_abort() in simple_abort.c
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
