The N used in the breakpoint and watchpoint register names is intended
to be an integer between 0 and 15 (inclusive) and will not compile when
used as is. This adds the accessors necessary to access all of these
breakpoint and watchpoint registers.
This adds the function implementations necessary to add exception
extensions support to AArch64.
All other architectures use uint32_t for interrupt levels and there is
no reason not to do so on AArch64.
This adds SMP support for AArch64 in cpukit and for the ZynqMP BSPs.
Cloning under Cygwin turned off executable permission on these
files. This shows them as modified even though they have not
explicitly been touched. Executable permission should not have
been on for these files so this is just a minor clean up.
Move _CPU_Fatal_halt() declaration to <rtems/score/cpuimpl.h> and make sure it
is a proper declaration of a function which does not return. Fix the type of
the error code. If necessary, add the implementation to cpu.c. Implementing
_CPU_Fatal_halt() as a function makes it possible to wrap this function for
example to fully test _Terminate().
Remove _CPU_SMP_Processor_event_broadcast() and
_CPU_SMP_Processor_event_receive(). These functions are hard to use since they
are subject to the lost wake up problem.
Break out system register definitions and accessors so that they're
usable by other parts of RTEMS.
The _CPU_ISR_Is_enabled() function operates on ISR cookies and so must
mask off the appropriate status bits. This also fixes the naming of the
parameters of the _CPU_ISR_* functions to indicate use of ISR cookies
instead of interrupt enable/disable levels.
This ensures that the saved SP register is sized appropriately depending
on the chosen ABI and prevents a warning in the libmisc stack checker.
Provide RTEMS_NO_RETURN also in case RTEMS_DEBUG is defined to prevent errors
like this:
error: no return statement in function returning non-void [-Werror=return-type]
Use C11 and C++11 standard means to declare a no-return function.
Close #4122.
This adds a CPU port for AArch64(ARMv8) with support for exceptions and
interrupts.
