* cpu/Makefile.am: Use @RTEMS_CPU@ instead of $(RTEMS_CPU).
* Makefile.am: Include compile.am, again.
* macros/rtems/score/README: Remove (Redundant with macros/README).
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* Makefile.am: Build libscore$(LIB_VARIANT).a instead of
$(ARCH)/libscore.a.
* cpu/Makefile.am: mips64orion port removed as mips port more
completely covers the MIPS family.
* cpu/mips64orion/.cvsignore, cpu/mips64orion/ChangeLog,
cpu/mips64orion/Makefile.am, cpu/mips64orion/asm.h,
cpu/mips64orion/configure.ac, cpu/mips64orion/cpu.c,
cpu/mips64orion/cpu_asm.S, cpu/mips64orion/cpu_asm.h,
cpu/mips64orion/idtcpu.h, cpu/mips64orion/idtmon.h,
cpu/mips64orion/iregdef.h, cpu/mips64orion/rtems/.cvsignore,
cpu/mips64orion/rtems/score/.cvsignore,
cpu/mips64orion/rtems/score/cpu.h,
cpu/mips64orion/rtems/score/mips64orion.h,
cpu/mips64orion/rtems/score/types.h: Removed.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
PR 533/bsps
* startup/linkcmds: Update linkcmds for gcc 3.3.2.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
Remove MACROS.
Remove MACROS.
PR 526/rtems
* src/threadcreateidle.c: Idle task name should be a string and
PR484 broke this.
PR 525/rtems
* include/rtems/system.h: Use RTEMS_INLINES instead of USE_INLINES.
* include/rtems/score/chain.h: Ditto.
* include/rtems/score/thread.h: Ditto.
* src/chain.c: Ditto.
* src/coremutexseize.c: Ditto.
* src/threadget.c: Ditto.
* Makefile.am: Don't use gmake to preinstall.
* src/coremsgseize.c, src/coremsgsubmit.c:
Remove unnecessary typecasts in assignments to
thread->Wait.return_argument.
PR 504/rtems
* include/rtems/score/coremutex.h: Add fatal error check for a task
blocking on a mutex when thread dispatching is disabled.
* cpu/hppa1.1/.cvsignore, cpu/hppa1.1/ChangeLog,
cpu/hppa1.1/Makefile.am, cpu/hppa1.1/configure.ac, cpu/hppa1.1/cpu.c,
cpu/hppa1.1/cpu_asm.S, cpu/hppa1.1/rtems/.cvsignore,
cpu/hppa1.1/rtems/score/.cvsignore, cpu/hppa1.1/rtems/score/cpu.h,
cpu/hppa1.1/rtems/score/cpu_asm.h, cpu/hppa1.1/rtems/score/hppa.h,
cpu/hppa1.1/rtems/score/types.h: Removed.
PR 489/rtems
* include/rtems/score/thread.h: Change struct
Thread_Control_struct.libc_reent to using struct _reent*.
* inline/rtems/score/thread.inl: Reflect change above.
PR 484/rtems
* src/threadcreateidle.c: Idle task name was initialized incorrectly.
* inline/rtems/score/userext.inl, macros/rtems/score/userext.inl:
Add missing cast.
* Makefile.am, include/rtems/score/object.h,
include/rtems/score/objectmp.h, src/objectmp.c, src/objectnametoid.c:
Added ID to name lookup service and changed name of id/name
translation status code. This propagated to multiple functions. The
user API service added was rtems_object_id_to_name()
* src/objectidtoname.c: New file.
PR 408/filesystem
* score/Makefile.am, score/include/rtems/score/thread.h: Added
sync() service. As part of adding this service, the
new RTEMS service rtems_iterate_over_all_threads() was also added.
This new service makes it easier to iterate over all the
tasks/threads in a system and perform an action on them.
* score/src/iterateoverthreads.c: New file.
* ChangeLog: Fixed screwup.
* ChangeLog: Add fileio to list of interactive tests.
* Makefile.am, include/rtems/score/thread.h: Add fileio to list of
interactive tests.
PR 430/rtems
* include/rtems/score/watchdog.h: _Watchdog_Ticks_since_boot should
be a VOLATILE variable.
* src/watchdoginsert.c: 'restart' algorithm needs to enforce
reloading the list head in case a TICK interrupt during ISR_Flash()
modified the list. This is achieved by a proper VOLATILE cast.
Also _Watchdog_Sync_count++ should be protected by _ISR_Disable
(prevent corruption in case ISR calls watchdoginsert)
* src/watchdogadjust.c: ISR protection added.
* src/watchdogtickle.c: ISR protection added.
NOTE: PowerPC BSPs using the new exception processing MUST BE UPDATED
to maintain _ISR_Nest_level. See also PR288 which provides fixes
for the affected BSPs distributed with RTEMS.
* cpu/Makefile.am: Add DIST_SUBDIRS = $(RTEMS_CPU).
PR 417/rtems
* src/coresemsurrender.c: Correct incorrect check for maximum_count
reported by Sergei Organov <osv@topconrd.ru>.
* src/threadloadenv.c: Removed warnings.
* src/objectmp.c: Removed warnings.
PR 356/bsps
* src/threadhandlerc: This patch makes RTEMS/PowerPC eabi compliant.
Let Thread_Handler verify that _init/_main are non-NULL
before calling them (gives the linker script/user more
freedom to handle special cases).
AMD a29k declared obsolete.
* cpu/Makefile.am: Removed reference.
* cpu/a29k/.cvsignore, cpu/a29k/ChangeLog, cpu/a29k/Makefile.am,
cpu/a29k/amd.ah, cpu/a29k/asm.h, cpu/a29k/configure.ac,
cpu/a29k/cpu.c, cpu/a29k/cpu_asm.S, cpu/a29k/pswmacro.ah,
cpu/a29k/register.ah, cpu/a29k/sig.S, cpu/a29k/rtems/.cvsignore,
cpu/a29k/rtems/score/.cvsignore, cpu/a29k/rtems/score/a29k.h,
cpu/a29k/rtems/score/cpu.h, cpu/a29k/rtems/score/cpu_asm.h,
cpu/a29k/rtems/score/types.h: Removed.
* src/objectmp.c: Corrected use of name parameter to reflect that it
is actually the name not a pointer to the name.
Makefile.am: Don't create $ARCH.
Makefile.am: Fix macro-file installation.
Makefile.am: Move include/rtems/score/cpuopts.h to STD_H_FILES.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* include/rtems/score/object.h, include/rtems/score/tod.h:
Added casts to eliminate warnings on 16 bit targets like the h8300.
* macros/rtems/score/object.inl: Keep consistent with inline version.
* src/heapgetinfo.c: Fixed comment.
* src/mpci.c: Removed warning.
* src/threadhandler.c: Prototype _init() and _main() if they are needed
to avoid a warning.
* macros/rtems/score/coremsg.inl: Add <string.h> to remove warning.
* src/threadidlebody.c: Add return 0 to avoid warning.
* src/coretodset.c: Correct calculation of ticks until next section
boundary. It was incorrectly based upon current time not the
time that is being set.
* src/Makefile.am: Build into libscore.a.
* include/rtems/score/apimutex.h (_API_Mutex_Lock): Per PR253
add the missing _ISR_Disable. This fix was already applied to
the old location (c/src/exec/score/...).
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* macros/rtems/score/object.inl: Corrected typos in
_Objects_Open, _Objects_Close, and _Objects_Namespace_remove.
* macros/rtems/score/object.inl: Corrected implementation of
to be consistent with the inline implementation.
