path: root/cpukit/score/ChangeLog (follow)
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-201-0/+5
| | | | | * include/rtems/system.h: Fix typo in yesterday's change: RTEMS_MULTILIBS.
* 2001-01-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-181-0/+7
| | | | | | | * include/rtems/system.h: Only include cpuopts.h when building a multilib configuration. Some ports still need targopts.h but this small modification lets those ports work non-multilib while fixing being fixed for multilib.
* 2002-01-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-0/+6
| | | | | | * include/rtems/seterr.h: Add do {..} while (0) in defines. Rename set_errno_and_return_minus_one into rtems_set_errno_and_return_minus_one.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-201-0/+6
| | | | | | * inline/rtems/score/object.inl, macros/rtems/score/object.inl: Add add casts to Objects_Id in _Objects_Build_ids to avoid implicit typecasts from enum to int16 on bit16 targets (here: h8300).
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-191-0/+4
| | | | * src/Makefile.am: Add multilib support.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-281-0/+9
| | | | | | | | | This was tracked as PR91. * include/rtems/score/isr.h, inline/rtems/score/isr.inl, macros/rtems/score/isr.inl: Modified to allow any port to provide its own implementation of the macro _ISR_Is_in_progress. If the port overrides this macro, it must provide a non-inlined function implementation.
* 2001-11-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-201-0/+8
| | | | | | | | * src/threadhandler.c: When __USE__MAIN__ is defined by the toolset, invoke the global constructors via __main. Reported as tested by Alexandra Kossovsky <sasha@oktet.ru> and Victor V. Vengerov <vvv@oktet.ru> in conjunction with a new set of tool RPMs (gcc2.95.3newlib1.9.0-3). This was tracked as GNATS PR tools/84.
* 2001-11-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-11-071-0/+8
| | | | | | | | | Reported by Todor.Todorov@barco.com and tracked as PR36. * include/rtems/score/object.h: Added prototype for _Objects_Get_by_index(). * src/objectget.c, src/objectgetisr.c: Corrected procedure for getting index from Id so it is correct and optimal for both single and multiprocessor configurations.
* 2001-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-221-0/+5
| | | | | * src/threadhandler.c: Use __USE_INIT_FINI__ since USE_INIT_FINI pollutes the application namespace.
* 2001-10-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-171-0/+4
| | | | * .cvsignore: Add stamp-h.in.
| | | | * include/Makefile.am: Fixed path to cpuopts-tmp.h.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-161-0/+13
| | | | | | | | | | | | | * include/rtems/Makefile.am: Remove. * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * macros/rtems/score/Makefile.am: Remove. * macros/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/rtems/score/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * Makefile.am: require automake-1.5
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-281-0/+7
| | | | | | | * include/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-27 Eric Norum <eric.norum@usask.ca>Joel Sherrill2001-09-271-0/+14
| | | | | | | * src/threadhandler.c: Now process C++ global constructors (_init) as part of the first task execution not in BSP space. This depends on the toolset defining USE_INIT_FINI so you have to have the right toolset version.
* 2001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-301-0/+13
| | | | | | | | | | | | | * src/coremutex.c, src/coremutexseize.c, src/coremutexsurrender.c, inline/rtems/score/coremutex.inl: The per thread field resource_count should only be manipulated when a mutex is priority ceiling or priority inherit. This was reported by Chris Johns <ccj@acm.org> who also noticed that the use of switches for all disciplines generated less efficient code than using explicit tests for the one or two cases we were really interested in. Further review of his modifications made it apparent that the "isa" methods to test mutex discipline were not being used so this modification was swept into the code as well.
* 2001-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-301-0/+7
| | | | | | | * src/coremutexseize.c: Add missing code for proper handling of nesting acquisitions. This only impacts building with inlines disabled on the source with the "fast mutex" optimizations. This was post the 4.5 branch and did not impact released versions.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-161-0/+6
| | | | | | * src/coremutexsurrender.c: Use holder thread not executing thread because even though they may and often are the same it is not guaranteed unless the proper attribute is set.
* 2001-08-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-161-0/+8
| | | | | | | | * include/rtems/score/coremsg.h, src/coremsgsubmit.c: Add a new return status to account for blocking sends. Otherwise, the caller will think that the returned message status will have the ultimate results of the operation. If the send times out, the final status will be in the return_code of the thread.
* 2001-08-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-08-091-0/+8
| | | | | | | | * include/rtems/score/coremsg.h, inline/rtems/score/coremsg.inl, src/coremsgsubmit.c: Unblocking message queue operations should NOT use _Thread_Executing for return status since it is permissible to invoke message send operations from an ISR. This was reported by Suvrat Gupta <suvrat@utstar.com>.
* 2000-05-25 Sergei Organov <osv@javad.ru>Joel Sherrill2001-05-251-0/+6
| | | | | | * macros/rtems/score/coresem.inl, inline/rtems/score/coresem.inl: Cut and paste problem incorrectly enabled interrupts twice with the first time being too early.
* 2001-05-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-05-091-0/+5
| | | | | * include/rtems/score/.cvsignore: Add stamp-h, cpuopts.h, cpuopts.h.in, cpuopts-tmp.h.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-0/+6
| | | | | | * include/rtems/Makefile.am, include/rtems/score/Makefile.am, inline/rtems/score/Makefile.am, macros/rtems/score/Makefile.am Apply include_*HEADERS instead of H_FILES.
* 2001-01-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-291-0/+5
| | | | | * src/objectextendinformation.c: Added include of string.h to eliminate warning.
* 2001-01-08 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-081-0/+5
| | | | | * src/threadinitialize.c: Fix my bad hack of Ralf's fp_area warning removal patch. :(
* 2001-01-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-081-0/+4
| | | | * src/threadinitialize.c: Removed warning.
* 2001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-01-031-0/+5
| | | | * rtems/score/cpu.h: Added _CPU_Initialize_vectors().
* 2000-12-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-191-0/+5
| | | | | * src/isr.c: Allocate the _ISR_Vector_table all the time not just when we are allocating an interrupt stack.
* 2000-12-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-131-0/+6
| | | | | | * include/rtems/score/isr.h, src/isr.c: Allocate it from the workspace rather than explicitly declaring it. This allows the size to be a non-constant from the perspective of score/cpu.
* 2000-12-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-12-011-0/+8
| | | | | | | | * macros/rtems/score/coresem.inl: Removed comments since convention calls for comments to be in inline versin. * macros/rtems/score/object.inl (Objects_Get_local_object): Fixed style to use _ prefix on variable names and use parentheses. * macros/rtems/score/object.inl (_Objects_Namespace_remove): Added.
* 2000-11-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-301-0/+18
| | | | | | | | | | | | | | | | | | * General effort to make things compile with macros not inlines * inline/rtems/score/coremutex.inl: Added comment indicating for macros there is another copy of _CORE_mutex_Seize_interrupt_trylock() in src/coremutexseize.c. * src/coremutexseize.c: Added body of _CORE_mutex_Seize_interrupt_trylock() for macro case. * macros/rtems/score/coremutex.inl: Added prototype for _CORE_mutex_Seize_interrupt_trylock() since there is a real body when macros are enabled. * macros/rtems/score/coresem.inl: Added macro implementation of _CORE_semaphore_Seize_isr_disable. * macros/score/Makefile.am: Fixed typos. * rtems/score/address.inl: Correct macro implementation of _Addresses_Is_aligned() so it would compile. * macros/rtems/score/coremsg.inl: Added closing parentheses.
* 2000-11-28 Chris Johns <ccj@acm.org>Joel Sherrill2000-11-281-0/+9
| | | | | | | | | * src/heapallocate.c: Do not allow the size to overflow when adjusting it. A test allocated a stack of -1 (~0). This actually resulted in a stack being allocated but with a size of 0xb. The allocator did not test the size to see if it rolled through 0 and so allowed the allocation to happen, the thread to get created. The task crashed as you would expect.
* 2000-11-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-11-031-0/+6
| | | | | | * include/rtems/system.h: Use proper conditional (RTEMS_POSIX_API) so prototypes for POSIX_MP_NOT_IMPLEMENTED(), POSIX_NOT_IMPLEMENTED(), POSIX_BOTTOM_REACHED() are actually included.
* 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-11-021-0/+5
| | | | | | * aclocal/canonicalize-tools.m4, aclocal/check-tool.m4, aclocal/prog-cc.m4, aclocal/prog-cxx.m4: Replace AC_CHECK_TOOL with an RTEMS specific but more restrictive autoconf macro.
* 2000-10-18 Nick Simon <Nick.SIMON@syntegra.bt.co.uk>Joel Sherrill2000-10-181-0/+6
| | | | | | * src/heapgetinfo.c, include/rtems/score/heap.h, src/Makefile.am: Added _Heap_Get_information() and information control block. * src/heapgetinfo.c: New file.
* 2000-09-25 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-251-0/+5
| | | | | * rtems/system.h: Switched a29k and hppa1.1 to using cpuopts.h not targopts.h to reduce dependency on BSP.
* 2000-09-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-201-0/+5
| | | | | * src/objectgetbyindex.c: Do not enable dispatching on an error path it was not disabled on.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+4
| | | | * src/Makefile.am: Include compile.am.
* 2000-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-08-301-0/+6
| | | | | | * Many files: Moved posix/include/rtems/posix/seterr.h to score/include/rtems/seterr.h so it would be available within all APIs.
* 2000-08-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-08-251-0/+4
| | | | * include/rtems/system.h: Include cpuopts.h for __i386__.
* Adding ChangeLogs.Joel Sherrill2000-08-101-0/+4
