This is the result of a sed script which converts all uses
of @{ into a consistent form.
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
http://www.google-melange.com/gci/task/view/google/gci2012/8032207
http://www.google-melange.com/gci/task/view/google/gci2012/8006220
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
This file contains the parts of <rtems/posix/psignal.h> that are only
necessary for the POSIX API implementation.
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
Use INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR on PowerPC for
_CPU_ISR_install_vector().
A BSP can supply an initial extension via the new optional
BSP_INITIAL_EXTENSION define. It will be the last in the initial
extension table.
The initial extensions remain now in a read-only table and will not be
copied to work space memory. The extension chains are statically
initialized. This makes it possible to call _User_extensions_Iterate()
independent of the system state. It is now guaranteed that the fatal
callout of the initial extensions will be called provided the stack
pointer, the read-only data, and code memory are valid.
The comment in confdefs.h shows how to do it:
An application can define its own scheduling policy by defining
CONFIGURE_SCHEDULER_USER and the following:
- CONFIGURE_SCHEDULER_ENTRY_POINTS
- CONFIGURE_MEMORY_FOR_SCHEDULER - base memory
- CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER - per task memory
The Configuration is now read-only and must be statically initialized
via confdefs.h or similar.
Delete rtems_configuration_get_table(),
rtems_configuration_set_stack_space_size(),
rtems_configuration_set_work_space_size(), and
rtems_configuration_set_microseconds_per_tick().
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
Add nanoseconds_per_tick to rtems_configuration_table. This value will
be derived from the microseconds_per_tick value. This avoids some
calculations at run-time.
Read-ahead requests were previously executed in the context of the
reading task. This blocks the reading task until the complete read
with read-ahead transfer is finished. A read-ahead task is introduced
to off-load the read-ahead transfer. This allows the reading task to
work with the requested block more quickly. The read-ahead is triggered
after two misses of ascending consecutive blocks or a read hit of a
block read by the most-recent read-ahead transfer. The read-ahead
feature is configurable and can be disabled.
The task stack size for the swap-out and worker tasks is now
configurable. The bdbuf task resources are now included in the work
space size estimate.
The implementation of RBTree_Next was using an awkward construction to detect
and avoid accessing the false root of the red-black tree. To deal with the
false root, RBTree_Next was comparing node parents with the control node.
Instead the false root can be detected by checking if the grandparent of a
node exists; the grandparent of the tree's true root is NULL by definition
so the root of the tree is found while walking up the tree by checking for
the non-existence of a grandparent.
This change propagates into the predecessor/successor and iterate functions.
Make default for rtems_rbtree functions be unprotected (preemption enabled)
unless an unprotected variant e.g. rtems_rbtree_xxx_unprotected is available.
for details.
The per file descriptor semaphore (field of rtems_libio_t) is unused in
RTEMS. There is a considerable memory overhead due to that. A
semaphore needs roughly 124 bytes which is huge compared to the
approximately 72 bytes for the file descriptor structure itself. Device
drivers can create their own synchronization primitives in the open
handler on demand.
