* | POSIX Timers submitted by Juan Zamorano Flores | Joel Sherrill | 1999-02-03 | 2 | -0/+12 |
| | | | | <jzamora@avellano.datsi.fi.upm.es>. | ||||
* | Moved stackchk.h to rtems subdirectory. | Joel Sherrill | 1998-12-03 | 1 | -1/+1 |
* | Added base version of file system infrastructure. This includes a major | Joel Sherrill | 1998-11-23 | 1 | -0/+4 |
| | | | | | | | | | | | | | | | | | | | | | | | | overhaul of the RTEMS system call interface. This base file system is the "In-Memory File System" aka IMFS. The design and implementation was done by the following people: + Joel Sherrill (joel@OARcorp.com) + Jennifer Averett (jennifer@OARcorp.com) + Steve "Mr Mount" Salitasc (salitasc@OARcorp.com) + Kerwin Wade (wade@OARcorp.com) PROBLEMS ======== + It is VERY likely that merging this will break the UNIX port. This can/will be fixed. + There is likely some reentrancy/mutual exclusion needed. + Eventually, there should be a "mini-IMFS" description table to eliminate links, symlinks, etc to save memory. All you need to have "classic RTEMS" functionality is technically directories and device IO. All the rest could be left out to save memory. | ||||
* | Added --disable-multiprocessing flag and modified a lot of files to make | Joel Sherrill | 1998-11-23 | 3 | -0/+25 |
| | | | | it work. | ||||
* | Corrected interrupt stack allocation. | Joel Sherrill | 1998-05-27 | 1 | -3/+7 |
* | Include memory for Ada task stacks. | Joel Sherrill | 1998-05-18 | 1 | -2/+2 |
* | Added default value for CONFIGURE_MAXIMUM_POSIX_THREADS since it is | Joel Sherrill | 1998-05-04 | 1 | -0/+1 |
| | | | | | used to calculate the amount of memory used by tasks whether the POSIX API is enabled or disabled. | ||||
* | Removed redundant "* 1024" which exploded the size of the workspace. | Joel Sherrill | 1998-04-30 | 1 | -2/+2 |
* | Added numerous entries to make the memory calculation more accurate: | Joel Sherrill | 1998-04-27 | 1 | -1/+67 |
| | | | | | | | | | | | | | + POSIX threads + Ada tasks + POSIX threads API support + POSIX condition variables + POSIX keys (still do not account for data fields) + POSIX mutexes + POSIX queued signals + added macro for extra memory for task stacks + default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS + extra memory for Ada task stacks | ||||
* | Changed to account for libio's maximum_semaphores as well as its | Joel Sherrill | 1998-04-18 | 1 | -1/+5 |
| | | | | | | memory requirements. Also added variable to tell libio how many file descriptors to allocate. | ||||
* | Numerous changes which in total greatly reduced the amount of source | Joel Sherrill | 1998-04-15 | 1 | -1/+9 |
| | | | | | | | | | | | | code in each BSP's bspstart.c. These changes were: + confdefs.h now knows libio's semaphore requirements + shared/main.c now copies Configuration to BSP_Configuration + shared/main.c fills in the Cpu_table with default values This removed the need for rtems_libio_config() and the constant BSP_LIBIO_MAX_FDS in every BSP. Plus now the maximum number of open files can now be set on the gcc command line. | ||||
* | Per suggestion from Eric Norum, went from one initial extension set | Joel Sherrill | 1998-04-15 | 3 | -7/+31 |
| | | | | | | to multiple. This lets the stack check extension be installed at system initialization time and avoids the BSP having to even know about its existence. | ||||
* | Account for interrupt stack space | Joel Sherrill | 1998-04-14 | 1 | -1/+12 |
* | Added stack checker extension | Joel Sherrill | 1998-04-14 | 1 | -2/+14 |
* | Now accounts for region used by RTEMS malloc and extension used | Joel Sherrill | 1998-04-14 | 1 | -4/+16 |
| | | | | by newlib. | ||||
* | Added misisng line continuation. | Joel Sherrill | 1998-02-20 | 1 | -1/+1 |
* | Accounted for fixed system overhead. | Joel Sherrill | 1998-02-19 | 1 | -2/+10 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 16 | -16/+16 |
* | Patch from Ralf Corsepius to reduce the amount of memory consumed by | Joel Sherrill | 1998-02-04 | 1 | -2/+6 |
| | | | | the workspace by default. | ||||
* | Added CONFIGURE_GNAT_KEYS to correct the number of keys configured | Joel Sherrill | 1997-12-23 | 1 | -12/+11 |
| | | | | | | | | | for GNAT. It was the number of Ada tasks when in fact the run-time only required a single key. Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account for resources allocated for each non-Ada task/thread which invokes the Ada run-time implicitly through an Ada call. | ||||
* | Added CONFIGURE_MEMORY_USER_OVERHEAD constant per Chris Johns request. | Joel Sherrill | 1997-11-18 | 1 | -1/+6 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 16 | -32/+32 |
* | Added GNAT configuration parameters. | Joel Sherrill | 1997-08-04 | 1 | -4/+19 |
* | Added postswitch extension. | Joel Sherrill | 1997-07-09 | 1 | -0/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 16 | -80/+80 |
* | enhanced rtems_shutdown_executive to insure that no attempt will | Joel Sherrill | 1997-04-09 | 1 | -1/+4 |
| | | | | be made to shut the system down when it is down. | ||||
* | was checking for null cpu_table -- short have been checking configuration | Joel Sherrill | 1997-04-02 | 1 | -1/+1 |
| | | | | table. | ||||
* | This set of changes is the build of what was required to convert to | Joel Sherrill | 1997-04-01 | 1 | -0/+135 |
| | | | | | | | | | | | | | | | | | | | | GNU autoconf. This is the first large step in allowing an RTEMS user to perform a one-tree build (per crossgcc FAQ) including RTEMS in the build process. With this change RTEMS is configured in built in the same style as the GNU tools, yet retains the basic structure of its traditional Makefiles (ala Tony Bennett). Jiri Gaisler (jgais@wd.estec.esa.nl) deserves (and received) a big thank you for doing this. There are still issues to be resolved but as of this commit, all target which can be built on a linux host have been using a modified version of the source Jiri submitted. This source was merged and most targets built in the tree before this commit. There are some issues which remain to be resolved but they are primarily related to host OS dependencies, script issues, the use of gawk for hack_specs, and the dependence on gcc snapshots. These will be resolved. | ||||
* | With the transition from command line macro definitions to targopts.h, | Joel Sherrill | 1997-01-28 | 1 | -3/+2 |
| | | | | | it was necessary to include system.h before checking if anything was defined. | ||||
* | switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE" | Joel Sherrill | 1996-07-03 | 1 | -4/+4 |
* | fields for init threads stuff said tasks. | Joel Sherrill | 1996-06-14 | 1 | -4/+4 |
* | added maximum_queued_signals to _POSIX_Default_configuration | Mark Johannes | 1996-06-13 | 1 | -0/+1 |
* | added posix configuration parameter maximum_queued_signals. | Joel Sherrill | 1996-06-13 | 1 | -0/+5 |
* | now passing maximum_queued_signals to posix signals manager initialization | Joel Sherrill | 1996-06-13 | 1 | -1/+3 |
* | Added include so _POSIX_signals_Manager_initialization is prototyped. | Joel Sherrill | 1996-06-13 | 1 | -0/+1 |
* | added initialization of posix signal manager. | Joel Sherrill | 1996-06-12 | 1 | -0/+2 |
* | added an assert if a pthread_t is not the same size as an Objects_Id | Joel Sherrill | 1996-06-03 | 1 | -2/+5 |
* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 1 | -13/+45 |
| | | | | or rtems initialization table in configuration table | ||||
* | fixed support for posix initialization threads table | Joel Sherrill | 1996-05-29 | 1 | -2/+22 |
* | Addressed RTEMS API initialization tasks table in a system without | Joel Sherrill | 1996-05-29 | 1 | -3/+7 |
| | | | | RTEMS initialization tasks. | ||||
* | Added default POSIX API configuration table. | Joel Sherrill | 1996-05-29 | 1 | -1/+13 |
* | split the inclusion of "EXTERN" data based on whether it was sapi, | Joel Sherrill | 1996-05-28 | 6 | -24/+38 |
| | | | | score, rtems api, or posix api related. | ||||
* | added maximum keys | Joel Sherrill | 1996-05-28 | 1 | -1/+1 |
* | new file | Joel Sherrill | 1996-05-28 | 1 | -0/+72 |
* | added ifndef's for the POSIX maximum field in the POSIX api configuration table | Joel Sherrill | 1996-05-28 | 1 | -1/+6 |
* | added posix api initialization call to init.c | Joel Sherrill | 1996-05-28 | 2 | -1/+5 |
| | | | | deleted a blank line in rtemsapi.c | ||||
* | made posix configuration information conditional so configurations wanting | Joel Sherrill | 1996-05-28 | 2 | -1/+49 |
| | | | | only the rtems api don't have to include it. | ||||
* | added initial posix configuration support | Joel Sherrill | 1996-05-28 | 3 | -41/+40 |
* | Removed prototyes for static inline routines and moved the comments into | Joel Sherrill | 1996-03-06 | 2 | -53/+20 |
| | | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana. | ||||
* | Changed io manager initialization routine to not be static and added it here. | Joel Sherrill | 1996-02-21 | 1 | -0/+37 |
