Delete rtems_configuration_get_smp_maximum_processors(). Delete
rtems_configuration_smp_maximum_processors variable. Add
maximum_processors field to rtems_configuration_table if RTEMS_SMP is
defined. Add rtems_configuration_get_maximum_processors().
Add and use rtems_libio_exit_helper. Add rtems_libio_exit().
The fclose(stdin) etc. makes no sense during exit. This would use the
_REENT structure of the thread calling _exit().
Rename open_dev_console() to rtems_libio_post_driver(). Rename
rtems_libio_supp_helper to rtems_libio_post_driver_helper.
Add and use rtems_libio_helper function type. Add and use
rtems_libio_helper_null() instead of NULL pointer.
Only one of the following can be defined.
+ CONFIGURE_APPLICATION_NEEDS_CLOCK_DRIVER
+ CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER
+ CONFIGURE_APPLICATION_NEEDS_TIMER_DRIVER
Otherwise it is a configuration error which can be detected at
compilation time.
This was not used by any BSP and obsolete now that unified memory
is an option for all BSPs.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
http://www.google-melange.com/gci/task/view/google/gci2012/8032207
http://www.google-melange.com/gci/task/view/google/gci2012/8006220
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
Do not return from rtems_initialize_start_multitasking() and call
rtems_fatal() instead with a fatal source of RTEMS_FATAL_SOURCE_EXIT and
a fatal code with the exit status.
Remove all bsp_cleanup() functions. The boot_card() is now a no return
function.
This file contains the parts of <rtems/posix/psignal.h> that are only
necessary for the POSIX API implementation.
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
Use INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR on PowerPC for
_CPU_ISR_install_vector().
A BSP can supply an initial extension via the new optional
BSP_INITIAL_EXTENSION define. It will be the last in the initial
extension table.
The initial extensions remain now in a read-only table and will not be
copied to work space memory. The extension chains are statically
initialized. This makes it possible to call _User_extensions_Iterate()
independent of the system state. It is now guaranteed that the fatal
callout of the initial extensions will be called provided the stack
pointer, the read-only data, and code memory are valid.
The comment in confdefs.h shows how to do it:
An application can define its own scheduling policy by defining
CONFIGURE_SCHEDULER_USER and the following:
- CONFIGURE_SCHEDULER_ENTRY_POINTS
- CONFIGURE_MEMORY_FOR_SCHEDULER - base memory
- CONFIGURE_MEMORY_PER_TASK_FOR_SCHEDULER - per task memory
The Configuration is now read-only and must be statically initialized
via confdefs.h or similar.
Delete rtems_configuration_get_table(),
rtems_configuration_set_stack_space_size(),
rtems_configuration_set_work_space_size(), and
rtems_configuration_set_microseconds_per_tick().
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
