path: root/cpukit/sapi (follow)
* With the transition from command line macro definitions to targopts.h,Joel Sherrill1997-01-281-3/+2
| | | | | it was necessary to include system.h before checking if anything was defined.
* switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"Joel Sherrill1996-07-031-4/+4
* fields for init threads stuff said tasks.Joel Sherrill1996-06-141-4/+4
* added maximum_queued_signals to _POSIX_Default_configurationMark Johannes1996-06-131-0/+1
* added posix configuration parameter maximum_queued_signals.Joel Sherrill1996-06-131-0/+5
* now passing maximum_queued_signals to posix signals manager initializationJoel Sherrill1996-06-131-1/+3
* Added include so _POSIX_signals_Manager_initialization is prototyped.Joel Sherrill1996-06-131-0/+1
* added initialization of posix signal manager.Joel Sherrill1996-06-121-0/+2
* added an assert if a pthread_t is not the same size as an Objects_IdJoel Sherrill1996-06-031-2/+5
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-13/+45
| | | | or rtems initialization table in configuration table
* fixed support for posix initialization threads tableJoel Sherrill1996-05-291-2/+22
* Addressed RTEMS API initialization tasks table in a system withoutJoel Sherrill1996-05-291-3/+7
| | | | RTEMS initialization tasks.
* Added default POSIX API configuration table.Joel Sherrill1996-05-291-1/+13
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-286-24/+38
| | | | score, rtems api, or posix api related.
* added maximum keysJoel Sherrill1996-05-281-1/+1
* new fileJoel Sherrill1996-05-281-0/+72
* added ifndef's for the POSIX maximum field in the POSIX api configuration tableJoel Sherrill1996-05-281-1/+6
* added posix api initialization call to init.cJoel Sherrill1996-05-282-1/+5
| | | | deleted a blank line in rtemsapi.c
* made posix configuration information conditional so configurations wantingJoel Sherrill1996-05-282-1/+49
| | | | only the rtems api don't have to include it.
* added initial posix configuration supportJoel Sherrill1996-05-283-41/+40
* Removed prototyes for static inline routines and moved the comments intoJoel Sherrill1996-03-062-53/+20
| | | | | | | | | | | | | | | the inline implementation. The impetus for this was twofold. First, it is incorrect to have static inline prototypes when using the macro implementation. Second, this reduced the number of lines in the include files seen by rtems.h by about 2000 lines. Next we restricted visibility for the inline routines to inside the executive itself EXCEPT for a handful of objects. This reduced the number of include files included by rtems.h by 40 files and reduced the lines in the include files seen by rtems.h by about 6000 lines. In total, these reduced the compile time of the entire RTEMS tree by 20%. This results in about 8 minutes savings on the SparcStation 10 morgana.
* Changed io manager initialization routine to not be static and added it here.Joel Sherrill1996-02-211-0/+37
* changed io manager initialization routine to not be staticJoel Sherrill1996-02-211-3/+1
* Removed the internal thread objects and dispersed its contents toJoel Sherrill1996-02-211-12/+14
| | | | | | | | | | the thread handler (IDLE), MPCI object (SYSI now MP Receive) and initialize_executive_early (IO initialization). The SYSI task no longer exists in a single processor configuration. This reduces single processor Workspace requirements by a TCB and a stack which is often larger than the minimum stack size. Moving the IO initialization plus accompanying BSP hooks eliminated an initialization ordering problem in which a global task could be created before the MPCI was initialized.
* idle thread now created before system initialization thread.Joel Sherrill1996-02-141-4/+1
| | | | Also system initialization thread only created in MP systems.
* Moved some initialization from the system initialization thread toJoel Sherrill1996-02-141-2/+42
| | | | | initialize_executive_early. This was done to clear up an ordering problem in which global tasks could be created before the MPCI layer was initialized.
* changed post task extension from user set to api set and added flagJoel Sherrill1996-02-131-2/+0
| | | | in each thread which must be set when the post switch extension is to be run.
* *** empty log message ***Joel Sherrill1996-02-121-4/+0
* typos fixedJoel Sherrill1995-10-312-21/+30
* posix support initially addedJoel Sherrill1995-09-266-21/+21
* moving files around and adding the exec/wrapup directoryJoel Sherrill1995-09-221-3/+4
* More file movement required api extension to be added to scoreJoel Sherrill1995-09-211-0/+3
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-4/+99
* Added... This is the Configuration Tables Template file.Joel Sherrill1995-09-111-0/+282
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-119-382/+292
* Moved _Thread_Information -> _RTEMS_tasks_Information.Joel Sherrill1995-08-232-2/+4
| | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-234-13/+19
* + Added object type field to object id.Joel Sherrill1995-08-181-0/+1
| | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-174-224/+208
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Fully tested on all in-house targetsJoel Sherrill1995-05-243-6/+13
* Initial revisionJoel Sherrill1995-05-1113-0/+1837
