* optman/, optman/.cvsignore, optman/Makefile.am, optman/no-ext.c,
optman/no-io.c: Removed entire contents of optman/ directory since
it has been moved.
* configure.ac: Use AS_IF instead of if/then/else.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix.
Add include/Makefile to CONFIG_FILES.
Add AC_ENABLE_MULITLIB.
Remove wrapup/rtems, wrapup/itron, wrapup/posix.
Remove */optman/Makefile from CONFIG_FILES.
* Makefile.am: Add include to SUBDIRS.
* rtems/Makefile.am: Remove optman from SUBDIRS.
* sapi/Makefile.am: Remove optman from SUBDIRS.
* include/Makefile.am: New file.
* include/rtems/bspIo.h: Relocated from lib/include.
* include/rtems/libio_.h: Relocated from lib/include.
* optman/Makefile.am: Add multilib support.
* src/Makefile.am: Add multilib support.
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* include/rtems/directives.h: Fixed typo.
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* include/confdefs.h: Fix real-time clock support.
* include/Makefile.am, include/rtems/Makefile.am,
inline/rtems/Makefile.am, macros/rtems/Makefile.am:
* include/confdefs.h: define CONFIGURE_NEWLIB_EXTENSION 0 if not
using NEWLIB, cleanup related comment.
* include/confdefs.h: include cpuopts.h, replace stubdr w/ devnull.
effects in RTEMS source code.
* include/confdefs.h: Replaced include of <sys/siginfo.h> with
<signal.h> since that file no longer exists.
* include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0
if there is no Classic API Initialization Tasks Table defined.
* include/confdefs.h: Modified code that accounts for initialization
task/threads with greater than minimum stack sizes so it would
compile even if optional APIs are disabled.
* include/confdefs.h: Account for initialization tasks and
threads which use larger than minimum stack sizes.
* include/rtems/io.h (rtems_driver_address_table): Added "_entry"
to all names.
* src/io.c: Accounted for above.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
that contains:
* Removes MKLIB
handling)
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
for RTEMS.
have have semaphores and message queue fields.
BSP needs to be eliminated.
parameter.
CONFIGURE_MAXIMUM_POSIX_SEMAPHORES.
CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE because in POSIX they are threads.
of POSIX Init thread to be user configured.
are:
PROBLEMS
can/will be fixed.
it work.
