* | + Added object type field to object id. | Joel Sherrill | 1995-08-18 | 1 | -0/+1 |
| | | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information | ||||
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 4 | -224/+208 |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | ||||
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 3 | -6/+13 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 13 | -0/+1837 |
