* itron/Makefile.am, libblock/Makefile.am, libcsupport/Makefile.am,
libfs/Makefile.am, libmisc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am:
Remove AM_CPPFLAGS += -I$(top_builddir).
* sapi/src/debug.c, sapi/src/exinit.c, sapi/src/extension.c,
sapi/src/extensioncreate.c, sapi/src/extensiondelete.c,
sapi/src/extensionident.c, sapi/src/fatal.c, sapi/src/io.c,
sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c:
Include config.h.
* sapi/src/fatal.c, score/src/interr.c:
Remove volatile on return type.
* sapi/include/rtems/io.h : size_t device_name_length.
* sapi/include/rtems/fatal.h, score/include/rtems/score/interr.h:
Remove volatile on return type (GCC-4.0 complains about them).
* httpd/Makefile.am, itron/Makefile.am, libblock/Makefile.am,
libcsupport/Makefile.am, libfs/Makefile.am, libmisc/Makefile.am,
libnetworking/Makefile.am, librpc/Makefile.am, posix/Makefile.am,
rtems/Makefile.am, sapi/Makefile.am, score/Makefile.am:
Eliminate CFLAGS_OPTIMIZE_V.
* rtems/src/eventsurrender.c: Remove bogus type casts.
* sapi/Makefile.am: Eliminate *_FILES.
* automake/compile.am, httpd/Makefile.am, itron/Makefile.am,
libblock/Makefile.am, libcsupport/Makefile.am, libfs/Makefile.am,
libmisc/Makefile.am, libnetworking/Makefile.am, librpc/Makefile.am,
posix/Makefile.am, rtems/Makefile.am, sapi/Makefile.am,
score/Makefile.am, wrapup/Makefile.am:
Remove build-variant support.
* sapi/include/rtems/sptables.h: Remove _RTEMS_version.
* sapi/Makefile.am: Install confdefs.h to $(includedir)/rtems.
* libblock/include/rtems/bdbuf.h: Include <rtems/chain.h> instead of <chain.h>.
* libblock/include/rtems/ide_part_table.h: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/malloc.c: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/mount.c: Include <rtems/chain.h> instead of <chain.h>.
* libcsupport/src/unmount.c: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs.h: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs_directory.c: Include <rtems/chain.h> instead of <chain.h>.
* libfs/src/imfs/imfs_load_tar.c: Include <rtems/chain.h> instead of <chain.h>.
* sapi/include/confdefs.h: Include <rtems/clockdrv.h> instead of <clockdrv.h>.
* sapi/include/confdefs.h: Include <rtems/console.h> instead of <console.h>.
* libfs/src/imfs/imfs_load_tar.c: Include <rtems/imfs.h> instead of <imfs.h>.
* libmisc/shell/cmds.c: Include <rtems/imfs.h> instead of <imfs.h>.
* libmisc/fsmount/fsmount.c: Include <rtems/imfs.h> instead of <imfs.h>.
* sapi/include/confdefs.h: Include <rtems/imfs.h> instead of <imfs.h>.
* itron/src/can_wup.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/chg_pri.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/cre_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/del_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/dis_dsp.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ena_dsp.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/eventflags.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/exd_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ext_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/fmempool.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/frsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/get_tid.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itronintr.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itronsem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/itrontime.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/mbox.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/mboxtranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/msgbuffer.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/msgbuffertranslatereturncode.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/network.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/port.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/prcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/prcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/preq_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/psnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ref_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rel_wai.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rot_rdq.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/rsm_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sig_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/slp_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/snd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/snd_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sta_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sus_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/sysmgmt.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/task.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/ter_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/trcv_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/trcv_mbx.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/tslp_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/tsnd_mbf.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/twai_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/vmempool.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/wai_sem.c: Include <rtems/itron.h> instead of <itron.h>.
* itron/src/wup_tsk.c: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/rtems/config.h: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/confdefs.h: Include <rtems/itron.h> instead of <itron.h>.
* sapi/src/itronapi.c: Include <rtems/itron.h> instead of <itron.h>.
* sapi/include/confdefs.h: Include <rtems/rtc.h> instead of <rtc.h>.
* sapi/include/confdefs.h: Include <rtems/timerdrv.h> instead of <timerdrv.h>.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h,
sapi/include/rtems/init.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/fatal.c,
sapi/src/io.c: Convert to using c99 fixed size types.
* libblock/src/bdbuf.c, libblock/src/ramdisk.c,
libcsupport/src/newlibc.c, libcsupport/src/sync.c,
libmisc/cpuuse/cpuuse.c, libmisc/monitor/mon-symbols.c,
libmisc/shell/cmds.c, libmisc/shell/shell.c,
libnetworking/kern/kern_sysctl.c, libnetworking/lib/ftpfs.c,
libnetworking/lib/tftpDriver.c, libnetworking/libc/gethostbydns.c,
libnetworking/libc/gethostbyht.c, libnetworking/libc/gethostnamadr.c,
libnetworking/libc/getnetbyht.c, libnetworking/libc/getnetnamadr.c,
libnetworking/libc/inet_addr.c, libnetworking/libc/linkaddr.c,
libnetworking/libc/map_v4v6.c, libnetworking/libc/ns_print.c,
libnetworking/libc/ns_ttl.c, libnetworking/libc/nsap_addr.c,
libnetworking/libc/rcmd.c, libnetworking/libc/res_debug.c,
libnetworking/libc/res_mkupdate.c, libnetworking/libc/res_query.c,
libnetworking/libc/res_send.c, libnetworking/libc/res_update.c,
libnetworking/net/radix.c, libnetworking/rtems/mkrootfs.c,
librpc/src/rpc/clnt_perror.c, librpc/src/rpc/rtems_rpc.c,
librpc/src/rpc/svc.c, sapi/include/confdefs.h,
score/macros/rtems/score/chain.inl, score/src/objectidtoname.c:
* ChangeLog: Merge-in itron/ChangeLog, posix/ChangeLog, score/ChangeLog,
sapi/ChangeLog, rtems/ChangeLog.
* itron/ChangeLog, posix/ChangeLog, score/ChangeLog, sapi/ChangeLog,
rtems/ChangeLog: Remove.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am, again.
* Makefile.am: Add libs to CLEANFILES
Set lib*_g_a_SOURCES = lib*_a_SOURCES.
* Makefile.am: Build libcsupport$(LIB_VARIANT).a instead of
$(ARCH)/libcsupport.a.
* Makefile.am: Build library using EXTRA_LIBRARIES and automake rules.
* Makefile.am: Use mkdir_p. Remove dirs from PRE/TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to compilation rules.
Add AM_CPPFLAGS += -I$(top_builddir).
* Makefile.am: Add $(dirstamp) to preinstallation rules.
Remove MACROS.
* Makefile.am: Reworked.
* include/confdefs.h, include/rtems/config.h,
include/rtems/extension.h, include/rtems/fatal.h,
include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h,
include/rtems/sptables.h, include/rtems/sptables.h.in,
inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c,
src/exinit.c, src/extension.c, src/extensioncreate.c,
src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c,
src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license
changed.
* src/extensionident.c: Added ID to name lookup service and changed
name of id/name translation status code. This propagated to multiple
functions. The user API service added was rtems_object_id_to_name()
PR 338/filesystem
* include/rtems/io.h, src/io.c: Side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
* Makefile.am: Don't create $ARCH as side-effect of compilation.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* src/io.c: Fixed some spacing.
* src/Makefile.am: Add libsrtems.a.
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* Jump table for single entry point removed.
* include/rtems/directives.h, src/entrytable.c: Removed.
* include/Makefile.am, src/Makefile.am, src/exinit.c: Modified to
reflect above.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/confdefs.h, src/exinit.c, src/extension.c, src/itronapi.c,
src/posixapi.c, src/rtemsapi.c: Modified as part of above.
* Include $(top_srcdir)/automake/*.am.
* src/exinit.c: Slightly rework initialization so there
is a valid thread as _Thread_Executing when the pre_tasking
hook is called. This allows one directives and malloc
to potentially use mutex protection.
* Per PR126, configuration structures now match docs.
* include/rtems/config.h: Use public data types.
* PR132 requested some tinkering ot lower memory.
* include/confdefs.h: Lowered footprint of device driver table
and statically configure user extensions. Now if no static
extensions are configured, then the table is not instantiated.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
