path: root/cpukit/sapi (follow)
* 2003-08-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-142-1/+7
| | | | | | * src/extensionident.c: Added ID to name lookup service and changed name of id/name translation status code. This propagated to multiple functions. The user API service added was rtems_object_id_to_name()
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-1110-18/+89
* Merger from rtems-4-6-branch.Ralf Corsepius2003-02-282-6/+5
* 2003-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-02-033-41/+7
| | | | | | PR 338/filesystem * include/rtems/io.h, src/io.c: Side-effect of fixing reentrancy problem with rtems_io_lookup_name() (API change).
* 2002-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-122-1/+4
| | | | * Makefile.am: Don't create $ARCH as side-effect of compilation.
* 2002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-096-112/+86
| | | | | | | | * include/Makefile.am: Remove. * inline/Makefile.am: Remove. * macros/Makefile.am: Remove. * src/Makefile.am: Remove. * Makefile.am: Merge-in removed Makefile.ams.
* 2002-08-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-302-1/+5
| | | | * src/io.c: Fixed some spacing.
* 2002-08-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-012-1/+9
| | | | * src/Makefile.am: Add libsrtems.a.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-1/+5
| | | | * src/Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-044-4/+10
| | | | | | | * Jump table for single entry point removed. * include/rtems/directives.h, src/entrytable.c: Removed. * include/Makefile.am, src/Makefile.am, src/exinit.c: Modified to reflect above.
* 2002-07-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-017-10/+47
| | | | | | | | | | | | | | | | | | | | | * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * include/confdefs.h, src/exinit.c, src/extension.c, src/itronapi.c, src/posixapi.c, src/rtemsapi.c: Modified as part of above.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-175-9/+9
| | | | * Include $(top_srcdir)/automake/*.am.
* 2001-05-09 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-05-092-5/+20
| | | | | | | * src/exinit.c: Slightly rework initialization so there is a valid thread as _Thread_Executing when the pre_tasking hook is called. This allows one directives and malloc to potentially use mutex protection.
* 2001-03-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-022-13/+18
| | | | | * Per PR126, configuration structures now match docs. * include/rtems/config.h: Use public data types.
* 2001-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-282-6/+29
| | | | | | | * PR132 requested some tinkering ot lower memory. * include/confdefs.h: Lowered footprint of device driver table and statically configure user extensions. Now if no static extensions are configured, then the table is not instantiated.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-286-5/+8
| | | | | | | | * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-03-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-156-120/+186
| | | | | | | * src/extension.c: Split to reduce minimum code size per PR134. * src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c: New files. src/Makefile.am: Modified to reflect above.
* 2002-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-071-0/+6
| | | | | | * optman/, optman/.cvsignore, optman/Makefile.am, optman/no-ext.c, optman/no-io.c: Removed entire contents of optman/ directory since it has been moved.
* 2001-12-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-041-1/+1
| | | | | | | | | | | | | | | | * configure.ac: Use AS_IF instead of if/then/else. Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix. Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix. Add include/Makefile to CONFIG_FILES. Add AC_ENABLE_MULITLIB. Remove wrapup/rtems, wrapup/itron, wrapup/posix. Remove */optman/Makefile from CONFIG_FILES. * Makefile.am: Add include to SUBDIRS. * rtems/Makefile.am: Remove optman from SUBDIRS. * sapi/Makefile.am: Remove optman from SUBDIRS. * include/Makefile.am: New file. * include/rtems/bspIo.h: Relocated from lib/include. * include/rtems/libio_.h: Relocated from lib/include.
* 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-12-192-1/+6
| | | | | * optman/Makefile.am: Add multilib support. * src/Makefile.am: Add multilib support.
* 2001-10-16 Chris Johns <ccj@acm.org>Joel Sherrill2001-10-166-9/+170
| | | | | | | | * include/confdefs.h, include/rtems/config.h, include/rtems/io.h, optman/no-io.c, src/exinit.c, src/io.c: Added a device driver register/unregister interface to allow device drivers to be installed and removed at runtime. This means you do not need devices present in the device table when you build.
* 2001-10-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-10-165-15/+63
| | | | | | | | | * include/rtems/Makefile.am: Remove. * include/Makefile.am: Handle subdirs, require automake-1.5. * inline/rtems/Makefile.am: Remove. * inline/Makefile.am: Handle subdirs, require automake-1.5. * macros/rtems/Makefile.am: Remove. * Makefile.am: require automake-1.5.
* 2001-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-10-121-0/+4
| | | | * include/rtems/directives.h: Fixed typo.
* 2001-09-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-282-1/+8
| | | | | | | * include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * include/Makefile.am: Use 'PREINSTALL_FILES ='. * inline/rtems/Makefile.am: Use 'PREINSTALL_FILES ='. * macros/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-0/+4
| | | | * optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-162-0/+11
| | | | * include/confdefs.h: Fix real-time clock support.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-052-4/+8
| | | | | | * include/Makefile.am, include/rtems/Makefile.am, inline/rtems/Makefile.am, macros/rtems/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-292-2/+8
| | | | | * include/confdefs.h: define CONFIGURE_NEWLIB_EXTENSION 0 if not using NEWLIB, cleanup related comment.
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-262-3/+14
| | | | * include/confdefs.h: include cpuopts.h, replace stubdr w/ devnull.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-312-1/+9
| | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * include/confdefs.h: Replaced include of <sys/siginfo.h> with <signal.h> since that file no longer exists.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-0/+6
| | | | | * include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0 if there is no Classic API Initialization Tasks Table defined.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-182-5/+29
| | | | | | * include/confdefs.h: Modified code that accounts for initialization task/threads with greater than minimum stack sizes so it would compile even if optional APIs are disabled.
* 2000-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-122-0/+11
| | | | | * include/confdefs.h: Account for initialization tasks and threads which use larger than minimum stack sizes.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-283-12/+18
| | | | | | * include/rtems/io.h (rtems_driver_address_table): Added "_entry" to all names. * src/io.c: Accounted for above.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+5
| | | | * src/Makefile.am, optman/Makefile.am: Include compile.am.
* Patch from Eric Valette <valette@crf.canon.fr> and Yacine El KolliJoel Sherrill2000-07-061-2/+2
| | | | <elkolli@crf.canon.fr> to add support for the mbx860_005b.
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-124-68/+138
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-138-0/+17
| | | | adds .cvsignore.
* Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-02-081-1/+0
* Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+28
| | | | | to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
* Patch rtems-rc-19991117-4.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-11-221-6/+6
* Updated copyright notice.Joel Sherrill1999-11-1718-36/+18
* Fixed so can be included multiple times in the executive source.Joel Sherrill1999-11-161-0/+9
* This patch adds the basic framework for the ITRON 3.0 API implementationJoel Sherrill1999-11-094-7/+346
| | | | for RTEMS.
* Fixed warning where initialized default POSIX API structure didJoel Sherrill1999-11-091-0/+2
| | | | have have semaphores and message queue fields.
* Fixed typo.Joel Sherrill1999-11-051-3/+3
* This is another pass at making sure that nothing outside the BSPJoel Sherrill1999-11-052-0/+5
| | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* The files in libcpu should not be directly dependent on any BSP. InJoel Sherrill1999-11-041-0/+46
| | | | | | | | | | | particular, using bsp.h, or getting information from the BSP which should properly be obtained from RTEMS is forbidden. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. The changes primarily eliminated the need to include bsp.h and peeking at BSP_Configuration. The use of Cpu_table in each BSP needs to be eliminated.
* Added CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM as a configurationJoel Sherrill1999-11-031-4/+3
| | | | parameter.
