* sapi/include/rtems/fatal.h: Add missing includes.
* sapi/include/confdefs.h,
score/include/rtems/score/schedulerpriority.h: Add comments.
score/include/rtems/score/schedulerpriority.h: C++ compatibility.
* sapi/include/confdefs.h, score/Makefile.am,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/scheduler.c, score/src/schedulerpriority.c,
score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadsetpriority.c, score/src/threadsettransient.c:
Significant clean up on Scheduler Plugin Interface. Names were
shortened. Missing operations added. Many scheduler files had
unneeded includes removed. Made pointer to scheduler information in
Thread_Control and Scheduler_Control a void * pointer because the
thread and scheduler wrapper should be unaware of scheduler types AND
this is broken for user provided schedulers.
* score/src/schedulerpriorityallocate.c,
score/src/schedulerpriorityenqueue.c,
score/src/schedulerpriorityenqueuefirst.c,
score/src/schedulerpriorityextract.c,
score/src/schedulerpriorityfree.c,
score/src/schedulerpriorityupdate.c: New files.
* score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerprioritythreadschedulerupdate.c: Removed.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
score/src/schedulerprioritythreadschedulerupdate.c,
score/src/threadclearstate.c, score/src/threadclose.c,
score/src/threadinitialize.c, score/src/threadready.c,
score/src/threadresume.c, score/src/threadsetpriority.c,
score/src/threadsetstate.c, score/src/threadsuspend.c: Simplify the
pluggable scheduler interface. Its configuration made a table
of available schedulers and set a pointer to one of the.
This was heavy handed since you can only use one scheduler
in an application. This configuration mechanism resulted in a
scheduler pointer being passed around when you could put all
scheduler configuration in an initialized structure.
* sapi/include/confdefs.h: Fix typo.
Jennifer Averett <jennifer.averett@oarcorp.com>
Add RTEMS Scheduler Simulator.
* sapi/include/confdefs.h: This adds some simple conditional
logic to disable portions of the configuration that are NOT supported
when configuring an RTEMS instance for use with a Scheduler Simulator
instance.
* sapi/include/confdefs.h, score/include/rtems/score/scheduler.h,
score/src/schedulerpriorityyield.c: Added attribute unused. Renamed
types and fields to follow the Score naming conventions.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/inline/rtems/score/schedulerpriority.inl: New files.
PR 1718/cpukit
* sapi/include/confdefs.h: POSIX threads are allocated twice the
minimum stack space by default. confdefs.h only accounts for one
minimum -- not the 2x factor.
* libmisc/stackchk/check.c: Make compile again.
* sapi/src/io.c, score/src/heap.c: Address dead assignment
issues found by clang.
PR 1673/cpukit
* sapi/src/chainappendnotify.c, sapi/src/chaingetnotify.c,
sapi/src/chaingetwait.c, sapi/src/chainprependnotify.c: New files.
* sapi/Makefile.am: Reflect changes above.
* sapi/include/rtems/chain.h: Declare
rtems_chain_append_with_notification(),
rtems_chain_prepend_with_notification(),
rtems_chain_get_with_notification(), and rtems_chain_get_with_wait().
* sapi/inline/rtems/chain.inl: Define
rtems_chain_append_with_empty_check(),
rtems_chain_prepend_with_empty_check(), and
rtems_chain_get_with_empty_check().
* sapi/include/rtems/chain.h: Move extern "C".
* sapi/include/confdefs.h: Include <rtems.h> to resolve all
dependencies.
PR 1658/cpukit
* sapi/src/exshutdown.c, score/include/rtems/score/interr.h: If the
system is not up, consider it a fatal error.
* sapi/inline/rtems/chain.inl: Added
rtems_chain_extract_unprotected().
* sapi/include/confdefs.h: Add configuration macros for Go
requirements.
PR 1635/cpukit
* sapi/src/exinit.c, score/Makefile.am, score/preinstall.am,
score/include/rtems/score/bitfield.h,
score/inline/rtems/score/priority.inl,
score/src/threadsettransient.c, score/src/threadsuspend.c:
Refactoring of priority handling, to isolate the bitmap
implementation of priorities in the supercore so that priority
management is a little more modular. This change is in anticipation
of scheduler implementations that can select how they manage tracking
priority levels / finding the highest priority ready task. Note that
most of the changes here are simple renaming, to clarify the use of
the bitmap-based priority management.
* score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/prioritybitmap.inl: New files.
* sapi/include/confdefs.h: Spelling.
* sapi/include/confdefs.h: Do not cover up user configuation mistakes
on filesystems -- cite them as errors.
* sapi/include/rtems/init.h: Mark rtems_shutdown_executive as a
noreturn method.
* libblock/include/rtems/ide_part_table.h, libblock/src/bdbuf.c,
libcsupport/src/__times.c, libcsupport/src/libio_init.c,
libcsupport/src/mallocfreespace.c, libcsupport/src/mount-mgr.c,
libcsupport/src/mount.c, libcsupport/src/rewinddir.c,
libcsupport/src/seekdir.c, libcsupport/src/telldir.c,
libcsupport/src/unmount.c, libfs/src/dosfs/fat.c,
libfs/src/dosfs/fat_fat_operations.c, libfs/src/dosfs/msdos_create.c,
libfs/src/dosfs/msdos_dir.c, libfs/src/dosfs/msdos_eval.c,
libfs/src/dosfs/msdos_file.c, libfs/src/dosfs/msdos_format.c,
libfs/src/dosfs/msdos_fsunmount.c, libfs/src/dosfs/msdos_initsupp.c,
libfs/src/dosfs/msdos_rename.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/shell/vis.c, libmisc/stackchk/check.c, sapi/src/posixapi.c,
telnetd/telnetd.c: Remove include of assert.h when it is not needed.
* libfs/src/nfsclient/src/nfs.c, libfs/src/nfsclient/src/nfs.c,
libfs/src/nfsclient/src/librtemsNfs.h: Renamed
rtems_nfsfs_initialize() in rtems_nfs_initialize().
* sapi/include/confdefs.h: Reflect changes above. Renamed
*_miniIMFS in *_MINIIMFS. Renamed *_NFSFS in *_NFS.
PR 1581/cpukit
* libcsupport/include/rtems/malloc.h, sapi/include/confdefs.h: Remove
extra * on function pointer declaration.
* sapi/include/confdefs.h: Add parameters for FIFOs and pipes since
they are distinct to the user.
* sapi/include/confdefs.h: Add CONFIGURE_MAXIMUM_FIFOS to account for
resources per FIFO instance.
* sapi/include/rtems/config.h: Remove ITRON.
* sapi/Makefile.am: Remove src/itronapi.c.
* sapi/src/itronapi.c: Remove.
* sapi/include/confdefs.h: Remove ITRON configuration parameters.
* sapi/include/confdefs.h: Remove RTEMS_COVERAGE conditionals whi.
* sapi/include/confdefs.h: Do not define a filesystem if
CONFIGURE_APPLICATION_DISABLE_FILESYSTEM is defined.
* libcsupport/include/rtems/libio.h, sapi/include/confdefs.h: Added
and use defines for file system types.
* libfs/src/imfs/fifoimfs_init.c: New file.
* libfs/Makefile.am: Reflect change above.
* libfs/src/imfs/imfs.h, libfs/src/imfs/imfs_eval.c,
libfs/src/imfs/imfs_init.c, libfs/src/imfs/imfs_initsupp.c,
libfs/src/imfs/miniimfs_init.c, libfs/src/pipe/fifo.c,
libfs/src/pipe/pipe.c, libfs/src/pipe/pipe.h: Pipe support is now
link-time optional.
* libcsupport/include/rtems/libio_.h: Declare
rtems_filesystem_mount_table_control.
* libcsupport/include/rtems/libio.h: Removed
rtems_filesystem_table_first(), rtems_filesystem_table_next() and
rtems_filesystem_table_node_t declarations. Declare
rtems_per_filesystem_routine, rtems_filesystem_iterate() and
rtems_filesystem_get_mount_handler().
* libcsupport/src/mount.c: Added rtems_filesystem_mounts_first() and
rtems_filesystem_mounts_next(). Simplify mount(). Removed
rtems_filesystem_mount_table_control_init. Use
* libcsupport/src/mount-mgr.c: Removed rtems_filesystem_mounts_first() and
rtems_filesystem_mounts_next(). Added rtems_filesystem_iterate() and
rtems_filesystem_get_mount_handler(). Use rtems_libio_lock() and
rtems_libio_unlock();
* sapi/include/confdefs.h, libmisc/shell/main_mount.c: Update for
mount API changes.
* sapi/include/confdefs.h: PR 1543. Make default file system when
nothing is defined IMFS not miniIMFS.
* libcsupport/include/rtems/libio.h: Make the struct name the same
as the typedef.
* sapi/include/confdefs.h: Fixes for use in C++.
* libcsupport/Makefile.am: Add mount-mgr.c.
* libcsupport/src/mount-mgr.c: New.
* include/rtems/fs.h: Added rtems_filesystem_location_mount.
* libcsupport/include/rtems/libio.h, libcsupport/src/mount.c: New
mount interface. It is similar to Linux.
* libcsupport/include/rtems/libio_.h: Remove the
init_fs_mount_table call.
* libcsupport/src/base_fs.c: Remove init_fs_mount_table_call. Use
the new mount call. Remove setting the root node in the global
pathloc. Mount does this now.
* libcsupport/src/privateenv.c: Remove the hack to set the root
mount table entry in the environment.
* libcsupport/src/unmount.cL Free the target string.
* libblock/src/bdpart-mount.c: New mount API.
* libfs/src/devfs/devfs.h, libfs/src/devfs/devfs_init.c,
libfs/src/dosfs/dosfs.h, libfs/src/dosfs/msdos.h,
libfs/src/dosfs/msdos_init.c, libfs/src/imfs/imfs.h,
libfs/src/imfs/imfs_eval.c, libfs/src/imfs/imfs_init.c,
libfs/src/nfsclient/src/librtemsNfs.h,
libfs/src/rfs/rtems-rfs-rtems.c, libfs/src/rfs/rtems-rfs.h,
libnetworking/lib/ftpfs.c, libnetworking/rtems/ftpfs.h,
libnetworking/rtems/tftp.h: New mount_h API.
* libfs/src/devfs/devfs_eval.c: Local include of extern ops.
* libfs/src/nfsclient/src/nfs.c: New mount API. Removed the mount
me call and fixed the initialisation to happen when mounting.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Remove mount
filesystem files.
* libmisc/fsmount/fsmount.c, libmisc/fsmount/fsmount.h: Updated to
the new mount table values.
* libmisc/shell/main_mount_ftp.c,
libmisc/shell/main_mount_msdos.c, libmisc/shell/main_mount_rfs.c,
libmisc/shell/main_mount_tftp.c: Removed.
* libmisc/shell/main_mount.c: Use the new mount API. Also access
the file system table for the file system types.
* libnetworking/lib/tftpDriver.c: Updated to the new mount
API. Fixed to allow mounting from any mount point. Also can now
have more than file system mounted.
* sapi/include/confdefs.h: Add file system configuration support.
* sapi/include/confdefs.h: New define CONFIGURE_SEMAPHORES for the
overall count of required semaphores. New define
CONFIGURE_LIBBLOCK_SEMAPHORES for the count of required disk and bdbuf
semaphores.
* sapi/inline/rtems/chain.inl: Added missing functions.
* libblock/src/ramdisk-config.c, sapi/include/confdefs.h:
CONFIGURE_DISABLE_CLASSIC_NOTEPADS is typo of
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS. Fix it.
_User_extensions_Add_API_set
* sapi/src/fatal.c: Formatting.
* sapi/include/rtems/config.h: Fixed typos (wrong case) in macro
expansion for
rtems_configuration_get_device_driver_table()
and
rtems_configuration_get_user_extension_table()
* cpukit/sapi/include/rtems/io.h: Documentation.
* cpukit/sapi/src/ioregisterdriver.c: Call from interrupt context is
an error.
* cpukit/sapi/src/iounregisterdriver.c: Disable preemption during
critical section.
* Makefile.am, preinstall.am: Added statvfs.h.
* libcsupport/Makefile.am: Add statvfs.c.
* libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c:
New.
* libcsupport/include/rtems/libio.h: Add a file system handler for
the statvfs call.
* libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c,
libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the
statvfs handler to NULL.
* include/rtems/fs.h: Add a second node access field for the RFS
file system to hold a directory offset while the existing field
holds the inode number. This save a rescan of the directory when
working with directories.
* libblock/include/rtems/bdbuf.h: Added references and user fields
to the buffer descriptor.
* libblock/src/bdbuf.c: Added dynamic buffer support for different
block sizes. Fixed a number of bugs.
* libblock/src/blkdev.c: Release the disk device on an error.
* libblock/src/diskdevs.c: Set the block size to the media block
size during initialisation of the disk device.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk.c: Updated the drivers to handle variable
block sizes.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any
buffers when an error occurs. The FAT buffer layer hangs onto a
single buffer while mounted. This should be fixed.
* sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain,
rtems_chain_is_node_off_chain, and rtems_chain_previous.
* score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain,
and _Chain_Is_node_off_chain.
* libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h:
New shell commands.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and
mknod commands.
* libmisc/shell/hexdump-display.c: Fixed the reopen bug which
showed up as a free with a bad pointer.
* libmisc/shell/main_mount.c: List the user adding file system
when listing the available file systems to mount.
* libmisc/shell/utils-cp.c: Remove the fixed static copy buffer
and use a large dynamic buffer.
* score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c,
score/src/objectallocate.c, score/src/objectfree.c: Remove
warnings.
* sapi/src/ioregisterdriver.c: Reowork so this is a context switch
disable critical section not interrupt disable critical section.
Hopefully eliminated dead code which showed up in coverage runs.
* sapi/include/rtems/io.h, sapi/src/ioregisterdriver.c: Documenation.
rtems_io_lookup_name() is now deprecated. Added
rtems_io_driver_io_error(). rtems_io_register_driver() is now
thread-safe.
