Remove the OBJECTS_UNLIMITED_OBJECTS flag for the memory size
configuration.
Close #3105.
Close #2502.
closes #2431.
Remove unused descriptor of merged free chunks from the free chain and
add them to the spare descriptors.
Update #2417.
This function is hard to support in alternative implementations. It has
no internal use case.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
Reserve a full minimum block to account for the heap protection enabled
via RTEMS_DEBUG.
The _Configure_From_workspace() already takes care that zero size
allocations contribute nothing to the workspace size estimate.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
New test sptests/timecounter01.
Update #2271.
Adds the possibility to register drivers before the IO Manager has
completed the initialization. Sometimes the BSP may want to register
a driver dynamically early in the boot process.
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
Rename CONFIGURE_IMFS_DISABLE_FCHMOD to CONFIGURE_IMFS_DISABLE_CHMOD.
Resurrect CONFIGURE_USE_MINIIMFS_AS_BASE_FILESYSTEM.
sapi/preinstall.am: Regenerated
Remove miniIMFS. Statically initialize the root IMFS.
Add configuration options to disable individual
features of the root IMFS, e.g.
o CONFIGURE_IMFS_DISABLE_CHOWN,
o CONFIGURE_IMFS_DISABLE_FCHMOD,
o CONFIGURE_IMFS_DISABLE_LINK,
o CONFIGURE_IMFS_DISABLE_MKNOD,
o CONFIGURE_IMFS_DISABLE_MOUNT,
o CONFIGURE_IMFS_DISABLE_READLINK,
o CONFIGURE_IMFS_DISABLE_RENAME,
o CONFIGURE_IMFS_DISABLE_RMNOD,
o CONFIGURE_IMFS_DISABLE_SYMLINK,
o CONFIGURE_IMFS_DISABLE_UNMOUNT, and
o CONFIGURE_IMFS_DISABLE_UTIME.
Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
Delete this variable since it is no longer necessary due to the thread
priority queue implementation change to use RB trees.
Ensure to report only once on SMP machines and ensure that the report is
output completely.
output.
Simplify _RBTree_Insert() and _RBTree_Extract(). Remove more
superfluous NULL pointer checks. Change _RBTree_Is_root() to use only
the node. Add parent parameter to _RBTree_Sibling(). Delete
_RBTree_Grandparent() and _RBTree_Parent_sibling().
Simplify _RBTree_Find_control(). Avoid superfluous NULL pointer checks.
Only use the parent pointer, since this pointer is never NULL for nodes
which are part of a tree.
Rename functions from *_off_rbtree() to *_off_tree().
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
Add Thread_Scheduler_control to collect scheduler related fields of the
TCB.
Use the PTHREAD mutexes and condition variables if available. This
helps on SMP configurations to avoid the home grown condition variables
via disabled preemption.
