* Makefile.am: Add $(dirstamp) to compilation rules.
Add AM_CPPFLAGS += -I$(top_builddir).
* Makefile.am: Add $(dirstamp) to preinstallation rules.
Remove MACROS.
* Makefile.am: Reworked.
* include/confdefs.h, include/rtems/config.h,
include/rtems/extension.h, include/rtems/fatal.h,
include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h,
include/rtems/sptables.h, include/rtems/sptables.h.in,
inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c,
src/exinit.c, src/extension.c, src/extensioncreate.c,
src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c,
src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license
changed.
* src/extensionident.c: Added ID to name lookup service and changed
name of id/name translation status code. This propagated to multiple
functions. The user API service added was rtems_object_id_to_name()
PR 338/filesystem
* include/rtems/io.h, src/io.c: Side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
* Makefile.am: Don't create $ARCH as side-effect of compilation.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* src/io.c: Fixed some spacing.
* src/Makefile.am: Add libsrtems.a.
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
* Jump table for single entry point removed.
* include/rtems/directives.h, src/entrytable.c: Removed.
* include/Makefile.am, src/Makefile.am, src/exinit.c: Modified to
reflect above.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/confdefs.h, src/exinit.c, src/extension.c, src/itronapi.c,
src/posixapi.c, src/rtemsapi.c: Modified as part of above.
* Include $(top_srcdir)/automake/*.am.
* src/exinit.c: Slightly rework initialization so there
is a valid thread as _Thread_Executing when the pre_tasking
hook is called. This allows one directives and malloc
to potentially use mutex protection.
* Per PR126, configuration structures now match docs.
* include/rtems/config.h: Use public data types.
* PR132 requested some tinkering ot lower memory.
* include/confdefs.h: Lowered footprint of device driver table
and statically configure user extensions. Now if no static
extensions are configured, then the table is not instantiated.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* src/extension.c: Split to reduce minimum code size per PR134.
* src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c:
New files.
src/Makefile.am: Modified to reflect above.
* optman/, optman/.cvsignore, optman/Makefile.am, optman/no-ext.c,
optman/no-io.c: Removed entire contents of optman/ directory since
it has been moved.
* configure.ac: Use AS_IF instead of if/then/else.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIX) for RTEMS_CPU==unix.
Add AC_DEFINE_UNQUOTED(RTEMS_UNIXLIB) for RTEMS_CPU==unix.
Add include/Makefile to CONFIG_FILES.
Add AC_ENABLE_MULITLIB.
Remove wrapup/rtems, wrapup/itron, wrapup/posix.
Remove */optman/Makefile from CONFIG_FILES.
* Makefile.am: Add include to SUBDIRS.
* rtems/Makefile.am: Remove optman from SUBDIRS.
* sapi/Makefile.am: Remove optman from SUBDIRS.
* include/Makefile.am: New file.
* include/rtems/bspIo.h: Relocated from lib/include.
* include/rtems/libio_.h: Relocated from lib/include.
* optman/Makefile.am: Add multilib support.
* src/Makefile.am: Add multilib support.
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* include/rtems/directives.h: Fixed typo.
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* include/confdefs.h: Fix real-time clock support.
* include/Makefile.am, include/rtems/Makefile.am,
inline/rtems/Makefile.am, macros/rtems/Makefile.am:
* include/confdefs.h: define CONFIGURE_NEWLIB_EXTENSION 0 if not
using NEWLIB, cleanup related comment.
* include/confdefs.h: include cpuopts.h, replace stubdr w/ devnull.
effects in RTEMS source code.
* include/confdefs.h: Replaced include of <sys/siginfo.h> with
<signal.h> since that file no longer exists.
* include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0
if there is no Classic API Initialization Tasks Table defined.
* include/confdefs.h: Modified code that accounts for initialization
task/threads with greater than minimum stack sizes so it would
compile even if optional APIs are disabled.
* include/confdefs.h: Account for initialization tasks and
threads which use larger than minimum stack sizes.
* include/rtems/io.h (rtems_driver_address_table): Added "_entry"
to all names.
* src/io.c: Accounted for above.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
that contains:
* Removes MKLIB
handling)
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
for RTEMS.
have have semaphores and message queue fields.
