<elkolli@crf.canon.fr> to add support for the mbx860_005b.
that contains:
* Removes MKLIB
handling)
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
for RTEMS.
have have semaphores and message queue fields.
BSP needs to be eliminated.
parameter.
CONFIGURE_MAXIMUM_POSIX_SEMAPHORES.
CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE because in POSIX they are threads.
of POSIX Init thread to be user configured.
are:
PROBLEMS
can/will be fixed.
it work.
used to calculate the amount of memory used by tasks whether the
POSIX API is enabled or disabled.
+ POSIX threads
+ Ada tasks
+ POSIX threads API support
+ POSIX condition variables
+ POSIX keys (still do not account for data fields)
+ POSIX mutexes
+ POSIX queued signals
+ added macro for extra memory for task stacks
+ default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+ extra memory for Ada task stacks
memory requirements.
Also added variable to tell libio how many file descriptors to allocate.
by newlib.
the workspace by default.
for GNAT. It was the number of Ada tasks when in fact the run-time
only required a single key.
Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account
for resources allocated for each non-Ada task/thread which invokes
the Ada run-time implicitly through an Ada call.
