Update #4269.
Use the right system initialization step for the stack allocator
initialization. Do the stack allocator initialization before the
workspace initialization so that _Memory_Allocate() can be used to get
memory for the allocator.
Use the type safe _Objects_Open_u32() instead. Return the object
identifier to enforce a common usage pattern.
The maximum frequency is UINT32_MAX. Converted to a uint64_t variable
it can be shifted by 32. The addition does not overflow since bin_per_s
- 1 is UINT32_MAX.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
Rename Classic API top-level group from Classic to RTEMSImplClassic.
Use RTEMSImplClassic as a prefix for the subgroups. Change the group
names to be in line with the API group names. Use common phrases for
the group brief descriptions.
Update #3706.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Move configuration related declarations and definitions to
<rtems/config.h>. The goal is to make <rtems.h> an include only header
file.
Add this application configuration option. This configuration option can be
used to reserve space for the dynamic linking of modules with thread-local
storage objects.
Add RTEMS_TASK_STORAGE_ALIGNMENT to define the minium alignment of a
thread-local storage size.
Update #4074.
Simplify object name to identifier directives. Using
_RTEMS_Name_to_id() to implement the directives enables a tail call
optimization.
Change license to BSD-2-Clause according to file history.
Update #3053.
Close #3978.
Add the _Copyright_Notice to a special linker set to prevent a garbage
collection of this item.
Close #3973.
Update #3973.
Close #3970.
Check that the extensions table is not NULL. Change format.
Update #3953.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The IO library used a POSIX key to store an optional POSIX user
environment pointer. This pulled in the POSIX keys support in every
application configuration. Add a user environment pointer to the thread
control block (TCB) instead. Applications which do not need the POSIX
user environment will just get an overhead of one pointer per thread.
Close #3882.
Use a dedicate system initialization step to zero the memory used for
the workspace and C program heap.
This avoids dead code in case CONFIGURE_ZERO_WORKSPACE_AUTOMATICALLY is
not configured.
Update #3861.
Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST
to allow applications and support functions to place system
initialization handlers behind the standard handlers.
Update #3838.
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
Update #3806.
Return the empty string instead of a NULL pointer if no version key is
available.
Update #3732.
Update #3706
Update #3706.
Allocate the per-CPU data for secondary processors directly from the
heap areas before heap initialization and not via
_Workspace_Allocate_aligned(). This avoids dependency on the workspace
allocator. It fixes also a problem on some platforms (e.g. QorIQ) where
at this early point in the system initialization the top of the RAM is
used by low-level startup code on secondary processors (boot pages).
Update #3507.
Statically allocate the objects information together with the initial
set of objects either via <rtems/confdefs.h>. Provide default object
informations with zero objects via librtemscpu.a. This greatly
simplifies the workspace size estimate. RTEMS applications which do not
use the unlimited objects option are easier to debug since all objects
reside now in statically allocated objects of the right types.
Close #3621.
Use functions instead of macros. Add missing
rtems_configuration_get_maximum_*() functions.
Update #3621.
Use Objects_Information::name_length to store this information.
Update #3621.
The sbintime_t is an efficient time format. Add the ability to convert
CPU counter ticks to/from sbintime_t.
This allows to build librtemscpu.a in one rush in the future.
Add rtems_counter_frequency() API function. Use it to initialize the
counter value converter via the new system initialization step
(RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation
and the counter converter. It avoids an unnecessary pull in of the
64-bit integer division from libgcc.
Update #3456.
An invalid heap usage such as a double free is usually a fatal error
since this indicates a use after free. Replace the use of printk() in
free() with a fatal error.
Update #3437.
Add RTEMS_FATAL_SOURCE_PANIC to rtems_fatal_source_text().
Update #3244.
Use a self-contained recursive mutex for API_Mutex_Control. The API
mutexes are protected against asynchronous thread cancellation.
Add dedicated mutexes for libatomic and TOD.
Close #2629.
Close #2630.
The previous rtems_panic() implementation was quite heavy weight. It
depended on _exit() which calls the global destructors. It used
fprintf(stderr, ...) for output which depends on an initialized console
device and the complex fprintf().
Introduce a new fatal source RTEMS_FATAL_SOURCE_PANIC for rtems_panic()
and output via vprintk().
Update #3244.
Add a default implementation of _arc4random_getentropy_fail with an
internal error.
Update #3239.
Provide functions to get the version string, major, minor and revision
numbers and the version control identifer that is a unique tag for
the version control system.
Update #3199.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
