2020-12-02 | rtems: Simplify includes in version.c | Sebastian Huber | 1 | -1/+1 | |
2020-04-16 | Canonicalize config.h include | Sebastian Huber | 1 | -1/+1 | |
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif | |||||
2019-09-09 | rtems: Make rtems_version_control_key() safer | Sebastian Huber | 1 | -1/+1 | |
Return the empty string instead of a NULL pointer if no version key is available. | |||||
2019-04-04 | doxygen: Added Version to API->Classic | Andreas Dachsberger | 1 | -1/+1 | |
Update #3706. | |||||
2017-11-10 | cpukit: Add a Version API. | Chris Johns | 1 | -0/+63 | |
Provide functions to get the version string, major, minor and revision numbers and the version control identifer that is a unique tag for the version control system. Update #3199. |
