path: root/cpukit/sapi/src/profilingreportxml.c (follow)
* cpukit, testsuite: Add rtems_printf and rtems_printer support.Chris Johns2016-05-251-57/+49
| | | | | | | | | | | | | | | | | | | This change adds rtems_printf and related functions and wraps the RTEMS print plugin support into a user API. All references to the plugin are removed and replaced with the rtems_printer interface. Printk and related functions are made to return a valid number of characters formatted and output. The function attribute to check printf functions has been added to rtems_printf and printk. No changes to remove warrnings are part of this patch set. The testsuite has been moved over to the rtems_printer. The testsuite has a mix of rtems_printer access and direct print control via the tmacros.h header file. The support for begink/endk has been removed as it served no purpose and only confused the code base. The testsuite has not been refactored to use rtems_printf. This is future work.
* sapi: Add arithmetic means to XML profiling reportSebastian Huber2014-04-281-9/+62
* sapi: Add SMP lock profiling app. level dataSebastian Huber2014-03-141-0/+78
* sapi: Add per-CPU profiling application level dataSebastian Huber2014-03-141-0/+89
* sapi: Add profiling application level supportSebastian Huber2014-03-141-0/+96
