path: root/cpukit/sapi/src/posixapi.c (follow)
* Fixed warning where initialized default POSIX API structure didJoel Sherrill1999-11-091-0/+2
| | | | have have semaphores and message queue fields.
* Added message queues and semaphores.Joel Sherrill1999-11-021-0/+11
* POSIX Timers submitted by Juan Zamorano FloresJoel Sherrill1999-02-031-0/+3
| | | | <jzamora@avellano.datsi.fi.upm.es>.
* With the transition from command line macro definitions to targopts.h,Joel Sherrill1997-01-281-3/+2
| | | | | it was necessary to include system.h before checking if anything was defined.
* fields for init threads stuff said tasks.Joel Sherrill1996-06-141-4/+4
* added maximum_queued_signals to _POSIX_Default_configurationMark Johannes1996-06-131-0/+1
* now passing maximum_queued_signals to posix signals manager initializationJoel Sherrill1996-06-131-1/+3
* Added include so _POSIX_signals_Manager_initialization is prototyped.Joel Sherrill1996-06-131-0/+1
* added initialization of posix signal manager.Joel Sherrill1996-06-121-0/+2
* added an assert if a pthread_t is not the same size as an Objects_IdJoel Sherrill1996-06-031-2/+5
* Added default POSIX API configuration table.Joel Sherrill1996-05-291-1/+13
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-11/+15
| | | | score, rtems api, or posix api related.
* new fileJoel Sherrill1996-05-281-0/+72
