* | score: Use ISR lock for IO driver registration | Sebastian Huber | 2016-03-14 | 1 | -2/+1 |
| | | | | | | Create implementation header file. Update #2555. | ||||
* | sapi misc: Clean up Doxygen GCI task #1 | Christopher Kerl | 2012-12-07 | 1 | -16/+8 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8011204 | ||||
* | 2007-05-29 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-05-29 | 1 | -0/+48 |
* sapi/Makefile.am, sapi/include/rtems/io.h, sapi/src/io.c: Split into one function per file execpt io.c which contains required initialization methods. * sapi/src/ioclose.c, sapi/src/iocontrol.c, sapi/src/iodata.c, sapi/src/ioinitialize.c, sapi/src/ioopen.c, sapi/src/ioread.c, sapi/src/ioregisterdriver.c, sapi/src/iounregisterdriver.c, sapi/src/iowrite.c: New files. |
