Create implementation header file.
Update #2555.
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
* cpukit/sapi/include/rtems/io.h: Documentation.
* cpukit/sapi/src/ioregisterdriver.c: Call from interrupt context is
an error.
* cpukit/sapi/src/iounregisterdriver.c: Disable preemption during
critical section.
* sapi/Makefile.am, sapi/include/rtems/io.h, sapi/src/io.c: Split into
one function per file execpt io.c which contains required
initialization methods.
* sapi/src/ioclose.c, sapi/src/iocontrol.c, sapi/src/iodata.c,
sapi/src/ioinitialize.c, sapi/src/ioopen.c, sapi/src/ioread.c,
sapi/src/ioregisterdriver.c, sapi/src/iounregisterdriver.c,
sapi/src/iowrite.c: New files.
