path: root/cpukit/sapi/src/ioinitialize.c (follow)
* score: Use ISR lock for IO driver registrationSebastian Huber2016-03-141-2/+1
| | | | | | Create implementation header file. Update #2555.
* sapi misc: Clean up Doxygen GCI task #1Christopher Kerl2012-12-071-16/+8
| | | | http://www.google-melange.com/gci/task/view/google/gci2012/8011204
* 2007-05-29 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-291-0/+48
* sapi/Makefile.am, sapi/include/rtems/io.h, sapi/src/io.c: Split into one function per file execpt io.c which contains required initialization methods. * sapi/src/ioclose.c, sapi/src/iocontrol.c, sapi/src/iodata.c, sapi/src/ioinitialize.c, sapi/src/ioopen.c, sapi/src/ioread.c, sapi/src/ioregisterdriver.c, sapi/src/iounregisterdriver.c, sapi/src/iowrite.c: New files.
