Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
Create implementation header file.
Update #2555.
Adds the possibility to register drivers before the IO Manager has
completed the initialization. Sometimes the BSP may want to register
a driver dynamically early in the boot process.
This simplifies the RTEMS initialization and helps to avoid a memory
overhead. The workspace demands of the IO manager were not included in
the <rtems/confdefs.h> workspace size estimate. This is also fixed as a
side-effect.
Update documentation and move "Specifying Application Defined Device
Driver Table" to the section end. This sub-section is not that
important for the user. Mentioning this at the beginning may lead to
confusion.
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
* libmisc/stackchk/check.c: Make compile again.
* sapi/src/io.c, score/src/heap.c: Address dead assignment
issues found by clang.
* sapi/include/rtems/extension.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c,
score/include/rtems/score/mpci.h, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h, score/src/coretod.c,
score/src/mpci.c, score/src/object.c, score/src/thread.c,
score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and
SuperCore Handler initialization routines to directly pull parameters
from configuration table.
* sapi/Makefile.am, sapi/include/rtems/io.h, sapi/src/io.c: Split into
one function per file execpt io.c which contains required
initialization methods.
* sapi/src/ioclose.c, sapi/src/iocontrol.c, sapi/src/iodata.c,
sapi/src/ioinitialize.c, sapi/src/ioopen.c, sapi/src/ioread.c,
sapi/src/ioregisterdriver.c, sapi/src/iounregisterdriver.c,
sapi/src/iowrite.c: New files.
* sapi/include/confdefs.h, sapi/src/io.c: Readded code to copy driver
table into Workspace but now it is only done if the application needs
extra slots for dynamic driver registration. Cleaned up
rtems_io_register_driver and rtems_io_unregister_driver code and
added numerous error cases to register.
* libmisc/Makefile.am, libmisc/monitor/mon-object.c,
libmisc/monitor/monitor.h, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/io.c: Eliminate maximum_drivers
configuration parameter since it was used to configure a no longer
used feature. Device names are now part of the filesystem not in a
table. This also eliminated the variables _IO_Number_of_devices and
_IO_Driver_name_table from RTEMS as well as the memory allocation
used to populate _IO_Driver_name_table.
* libmisc/monitor/mon-dname.c: Removed.
* itron/Makefile.am, itron/src/eventflags.c, itron/src/fmempool.c,
itron/src/itronintr.c, itron/src/itrontime.c, itron/src/network.c,
itron/src/port.c, itron/src/sysmgmt.c, itron/src/task.c,
itron/src/vmempool.c, posix/Makefile.am, posix/src/pthread.c,
rtems/src/taskinitusers.c, rtems/src/tasks.c,
sapi/include/confdefs.h, sapi/src/io.c: Various modification to
reduce executable size. Most were refactoring of files. Split ITRON
API files. Implemented mechanism to avoid initialization task/thread
loop being linked in when that style of task initialization was not
being used.
* itron/src/acp_por.c, itron/src/act_cyc.c, itron/src/cal_por.c,
itron/src/chg_iXX.c, itron/src/clr_flg.c, itron/src/cre_flg.c,
itron/src/cre_mpf.c, itron/src/cre_mpl.c, itron/src/cre_por.c,
itron/src/def_alm.c, itron/src/def_cyc.c, itron/src/def_exc.c,
itron/src/def_int.c, itron/src/def_svc.c, itron/src/del_flg.c,
itron/src/del_mpf.c, itron/src/del_mpl.c, itron/src/del_por.c,
itron/src/dis_int.c, itron/src/dly_tsk.c, itron/src/ena_int.c,
itron/src/fwd_por.c, itron/src/get_blf.c, itron/src/get_blk.c,
itron/src/get_tim.c, itron/src/get_ver.c, itron/src/itroninittasks.c,
itron/src/loc_cpu.c, itron/src/nget_nod.c, itron/src/nget_ver.c,
itron/src/nrea_dat.c, itron/src/nwri_dat.c, itron/src/pacp_por.c,
itron/src/pcal_por.c, itron/src/pget_blf.c, itron/src/pget_blk.c,
itron/src/pol_flg.c, itron/src/ref_alm.c, itron/src/ref_cfg.c,
itron/src/ref_cyc.c, itron/src/ref_flg.c, itron/src/ref_iXX.c,
itron/src/ref_mpf.c, itron/src/ref_mpl.c, itron/src/ref_por.c,
itron/src/ref_sys.c, itron/src/rel_blf.c, itron/src/rel_blk.c,
itron/src/ret_int.c, itron/src/ret_tmr.c, itron/src/ret_wup.c,
itron/src/rpl_rdv.c, itron/src/set_flg.c, itron/src/set_tim.c,
itron/src/tacp_por.c, itron/src/tcal_por.c, itron/src/tget_blf.c,
itron/src/tget_blk.c, itron/src/twai_flg.c, itron/src/unl_cpu.c,
itron/src/wai_flg.c, posix/src/pthreadinitthreads.c: New files.
* sapi/src/io.c: Fix spacing.
* sapi/include/rtems/io.h, sapi/src/io.c: Change rtems_io_register_name
to take a const char *.
* sapi/src/debug.c, sapi/src/exinit.c, sapi/src/extension.c,
sapi/src/extensioncreate.c, sapi/src/extensiondelete.c,
sapi/src/extensionident.c, sapi/src/fatal.c, sapi/src/io.c,
sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c:
Include config.h.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h,
sapi/include/rtems/init.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/fatal.c,
sapi/src/io.c: Convert to using c99 fixed size types.
* include/confdefs.h, include/rtems/config.h,
include/rtems/extension.h, include/rtems/fatal.h,
include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h,
include/rtems/sptables.h, include/rtems/sptables.h.in,
inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c,
src/exinit.c, src/extension.c, src/extensioncreate.c,
src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c,
src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license
changed.
PR 338/filesystem
* include/rtems/io.h, src/io.c: Side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
* src/io.c: Fixed some spacing.
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* include/rtems/io.h (rtems_driver_address_table): Added "_entry"
to all names.
* src/io.c: Accounted for above.
PROBLEMS
can/will be fixed.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
