Move configuration related declarations and definitions to
<rtems/config.h>. The goal is to make <rtems.h> an include only header
file.
Close #3978.
Close #3970.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
* sapi/src/getversionstring.c: Include <rtems.h> (Missing prototype).
* rtems/include/rtems.h, sapi/Makefile.am: Add simple helper to get
RTEMS version string.
* sapi/src/getversionstring.c: New file.
