path: root/cpukit/sapi/src/fatal.c (unfollow)
2022-02-28sapi/src/*.c: Change license to BSD-2Joel Sherrill1-3/+22
Updates #3053.
2020-12-02sapi: Canonicalize @defgroup and @file commentsSebastian Huber1-3/+3
Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706.
2020-04-16Canonicalize config.h includeSebastian Huber1-1/+1
Use the following variant which was already used by most source files: #ifdef HAVE_CONFIG_H #include "config.h" #endif
2019-03-14Remove superfluous <rtems/system.h> includesSebastian Huber1-1/+0
2016-12-09score: Remove fatal is internal indicatorSebastian Huber1-1/+1
The fatal is internal indicator is redundant since the fatal source and error code uniquely identify a fatal error. Keep the fatal user extension is internal parameter for backward compatibility and set it to false always. Update #2825.
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2014-02-21score: Rename _Internal_error_Occurred()Sebastian Huber1-1/+1
Rename _Internal_error_Occurred() into _Terminate().
2012-12-07sapi misc: Clean up Doxygen GCI task #1Christopher Kerl1-11/+9
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill1-2/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2009-11-092009-11-09 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-3/+2
* sapi/src/fatal.c: Formatting.
2005-01-282005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-0/+4
* sapi/src/debug.c, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/extensioncreate.c, sapi/src/extensiondelete.c, sapi/src/extensionident.c, sapi/src/fatal.c, sapi/src/io.c, sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c: Include config.h.
2005-01-232005-01-23 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+1
* sapi/src/fatal.c, score/src/interr.c: Remove volatile on return type.
2004-03-292004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius1-1/+1
* sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h, sapi/include/rtems/init.h, sapi/include/rtems/io.h, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/fatal.c, sapi/src/io.c: Convert to using c99 fixed size types.
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* include/confdefs.h, include/rtems/config.h, include/rtems/extension.h, include/rtems/fatal.h, include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h, include/rtems/sptables.h, include/rtems/sptables.h.in, inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c, src/exinit.c, src/extension.c, src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c, src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license changed.
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
1995-09-26posix support initially addedJoel Sherrill1-1/+1
1995-09-11The word "RTEMS" almost completely removed from the core.Joel Sherrill1-20/+4
Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API.
