* | Canonicalize config.h include | Sebastian Huber | 2020-04-16 | 1 | -1/+1 |
* | score: Static Objects_Information initialization | Sebastian Huber | 2018-12-14 | 1 | -30/+30 |
| | | | | | | | | | | | Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621. | ||||
* | rtems: Use object information to get config max | Sebastian Huber | 2018-12-14 | 1 | -1/+1 |
| | | | | | | | Use functions instead of macros. Add missing rtems_configuration_get_maximum_*() functions. Update #3621. | ||||
* | score: Remove Objects_Information::is_string | Sebastian Huber | 2018-12-07 | 1 | -2/+1 |
| | | | | | | Use Objects_Information::name_length to store this information. Update #3621. | ||||
* | score: Simplify _Objects_Initialize_information() | Sebastian Huber | 2016-04-21 | 1 | -5/+1 |
| | | | | | | Remove unused supports_global parameter. Convert _Objects_Initialize_information() to a macro to avoid use of RTEMS_MULTIPROCESSING define for each caller. | ||||
* | Optional Extensions initialization | Sebastian Huber | 2016-02-03 | 1 | -5/+11 |
| | | | | Update #2408. | ||||
* | score: Create object implementation header | Sebastian Huber | 2013-07-26 | 1 | -1/+0 |
| | | | | | | Move implementation specific parts of object.h and object.inl into new header file objectimpl.h. The object.h contains now only the application visible API. | ||||
* | sapi: Create extension implementation header | Sebastian Huber | 2013-07-23 | 1 | -1/+1 |
| | | | | | | Move implementation specific parts of extension.h and extension.inl into new header file extensionimpl.h. The extension.h contains now only the application visible API. | ||||
* | sapi misc: Clean up Doxygen GCI task #1 | Christopher Kerl | 2012-12-07 | 1 | -10/+8 |
| | | | | http://www.google-melange.com/gci/task/view/google/gci2012/8011204 | ||||
* | sapi: Use rtems_config*_get_maximum_extensions | Sebastian Huber | 2012-11-07 | 1 | -1/+1 |
* | 2011-07-24 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-07-24 | 1 | -2/+1 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * ftpd/ftpd.c, libcsupport/src/geteuid.c, libcsupport/src/getgroups.c, libcsupport/src/getpgrp.c, libcsupport/src/getpid.c, libcsupport/src/getppid.c, libcsupport/src/setpgid.c, libcsupport/src/setsid.c, libcsupport/src/utsname.c, libmisc/stackchk/check.c, posix/include/rtems/posix/mqueue.h, posix/inline/rtems/posix/cond.inl, posix/inline/rtems/posix/mqueue.inl, posix/inline/rtems/posix/mutex.inl, posix/inline/rtems/posix/pthread.inl, posix/inline/rtems/posix/semaphore.inl, posix/inline/rtems/posix/timer.inl, posix/src/alarm.c, posix/src/barrierattrdestroy.c, posix/src/barrierattrgetpshared.c, posix/src/barrierattrinit.c, posix/src/barrierattrsetpshared.c, posix/src/cleanuppop.c, posix/src/cleanuppush.c, posix/src/clockgetcpuclockid.c, posix/src/clockgetenableattr.c, posix/src/clockgetres.c, posix/src/clockgettime.c, posix/src/clocksetenableattr.c, posix/src/clocksettime.c, posix/src/cond.c, posix/src/condattrdestroy.c, posix/src/condattrgetpshared.c, posix/src/condattrinit.c, posix/src/condattrsetpshared.c, posix/src/condbroadcast.c, posix/src/conddefaultattributes.c, posix/src/conddestroy.c, posix/src/condinit.c, posix/src/condsignal.c, posix/src/condsignalsupp.c, posix/src/condtimedwait.c, posix/src/condwait.c, posix/src/condwaitsupp.c, posix/src/keygetspecific.c, posix/src/keyrundestructors.c, posix/src/keysetspecific.c, posix/src/mprotect.c, posix/src/mqueue.c, posix/src/mqueuecreatesupp.c, posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c, posix/src/mqueuenotify.c, posix/src/mqueuereceive.c, posix/src/mqueuesend.c, posix/src/mqueuesendsupp.c, posix/src/mqueuesetattr.c, posix/src/mqueuetimedreceive.c, posix/src/mqueuetimedsend.c, posix/src/mqueuetranslatereturncode.c, posix/src/mqueueunlink.c, posix/src/mutex.c, posix/src/mutexattrdestroy.c, posix/src/mutexattrgetprioceiling.c, posix/src/mutexattrgetprotocol.c, posix/src/mutexattrgetpshared.c, posix/src/mutexattrinit.c, posix/src/mutexattrsetprioceiling.c, posix/src/mutexattrsetprotocol.c, posix/src/mutexattrsetpshared.c, posix/src/mutexdestroy.c, posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c, posix/src/mutexlock.c, posix/src/mutexlocksupp.c, posix/src/mutexsetprioceiling.c, posix/src/mutextimedlock.c, posix/src/mutextrylock.c, posix/src/mutexunlock.c, posix/src/nanosleep.c, posix/src/psignal.c, posix/src/psignalchecksignal.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalclearsignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadinitthreads.c, posix/src/rwlockattrdestroy.c, posix/src/rwlockattrgetpshared.c, posix/src/rwlockattrinit.c, posix/src/rwlockattrsetpshared.c, posix/src/semaphore.c, posix/src/semaphoredeletesupp.c, posix/src/semaphorenametoid.c, posix/src/semaphorewaitsupp.c, posix/src/semclose.c, posix/src/semdestroy.c, posix/src/semgetvalue.c, posix/src/seminit.c, posix/src/semopen.c, posix/src/sempost.c, posix/src/semtimedwait.c, posix/src/semtrywait.c, posix/src/semunlink.c, posix/src/semwait.c, posix/src/sysconf.c, posix/src/testcancel.c, posix/src/ualarm.c, rtems/src/clockgetuptime.c, rtems/src/clockset.c, rtems/src/clocksetnsecshandler.c, rtems/src/clocktick.c, rtems/src/clocktodtoseconds.c, rtems/src/clocktodvalidate.c, rtems/src/dpmem.c, rtems/src/dpmemcreate.c, rtems/src/dpmemdelete.c, rtems/src/dpmemexternal2internal.c, rtems/src/dpmemident.c, rtems/src/dpmeminternal2external.c, rtems/src/event.c, rtems/src/eventmp.c, rtems/src/eventreceive.c, rtems/src/eventseize.c, rtems/src/eventsend.c, rtems/src/eventsurrender.c, rtems/src/eventtimeout.c, rtems/src/mp.c, rtems/src/msg.c, rtems/src/msgmp.c, rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c, rtems/src/msgqcreate.c, rtems/src/msgqdelete.c, rtems/src/msgqflush.c, rtems/src/msgqgetnumberpending.c, rtems/src/msgqident.c, rtems/src/msgqreceive.c, rtems/src/msgqtranslatereturncode.c, rtems/src/msgqurgent.c, rtems/src/part.c, rtems/src/partcreate.c, rtems/src/partdelete.c, rtems/src/partgetbuffer.c, rtems/src/partident.c, rtems/src/partmp.c, rtems/src/partreturnbuffer.c, rtems/src/ratemon.c, rtems/src/ratemoncancel.c, rtems/src/ratemoncreate.c, rtems/src/ratemondelete.c, rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c, rtems/src/ratemonident.c, rtems/src/ratemonperiod.c, rtems/src/ratemonresetstatistics.c, rtems/src/ratemontimeout.c, rtems/src/region.c, rtems/src/regioncreate.c, rtems/src/regiondelete.c, rtems/src/regionextend.c, rtems/src/regiongetfreeinfo.c, rtems/src/regiongetinfo.c, rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c, rtems/src/regionident.c, rtems/src/regionmp.c, rtems/src/regionprocessqueue.c, rtems/src/regionresizesegment.c, rtems/src/regionreturnsegment.c, rtems/src/rtemsobjectgetclassicname.c, rtems/src/rtemstimer.c, rtems/src/sem.c, rtems/src/semcreate.c, rtems/src/semdelete.c, rtems/src/semflush.c, rtems/src/semident.c, rtems/src/semmp.c, rtems/src/semobtain.c, rtems/src/semrelease.c, rtems/src/semtranslatereturncode.c, rtems/src/signal.c, rtems/src/signalcatch.c, rtems/src/signalmp.c, rtems/src/signalsend.c, rtems/src/taskcreate.c, rtems/src/taskdelete.c, rtems/src/taskgetnote.c, rtems/src/taskident.c, rtems/src/taskinitusers.c, rtems/src/taskissuspended.c, rtems/src/taskmp.c, rtems/src/taskrestart.c, rtems/src/taskresume.c, rtems/src/tasks.c, rtems/src/tasksetnote.c, rtems/src/tasksetpriority.c, rtems/src/taskstart.c, rtems/src/tasksuspend.c, rtems/src/taskwakeafter.c, rtems/src/taskwakewhen.c, rtems/src/timercancel.c, rtems/src/timercreate.c, rtems/src/timerdelete.c, rtems/src/timerfireafter.c, rtems/src/timerfirewhen.c, rtems/src/timergetinfo.c, rtems/src/timerident.c, rtems/src/timerreset.c, rtems/src/timerserverfireafter.c, rtems/src/timerserverfirewhen.c, sapi/src/debug.c, sapi/src/extension.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c, score/src/apiext.c, score/src/chain.c, score/src/corebarrier.c, score/src/corebarrierrelease.c, score/src/corebarrierwait.c, score/src/coremsgbroadcast.c, score/src/coremsgclose.c, score/src/coremsgflush.c, score/src/coremsgflushsupp.c, score/src/coremsgflushwait.c, score/src/coremsginsert.c, score/src/coremsgseize.c, score/src/coremsgsubmit.c, score/src/coremutex.c, score/src/coremutexflush.c, score/src/coremutexseize.c, score/src/corerwlock.c, score/src/corerwlockobtainread.c, score/src/corerwlockobtainwrite.c, score/src/corerwlockrelease.c, score/src/coresem.c, score/src/coresemflush.c, score/src/coresemsurrender.c, score/src/corespinlock.c, score/src/corespinlockrelease.c, score/src/corespinlockwait.c, score/src/coretod.c, score/src/coretodset.c, score/src/coretodtickle.c, score/src/heap.c, score/src/interr.c, score/src/mpci.c, score/src/objectallocate.c, score/src/objectextendinformation.c, score/src/objectfree.c, score/src/objectget.c, score/src/objectgetisr.c, score/src/objectgetnext.c, score/src/objectgetnoprotection.c, score/src/objectinitializeinformation.c, score/src/objectmp.c, score/src/objectnametoid.c, score/src/objectnametoidstring.c, score/src/objectshrinkinformation.c, score/src/rbtree.c, score/src/threaddelayended.c, score/src/threadhandler.c, score/src/threadinitialize.c, score/src/threadloadenv.c, score/src/threadmp.c, score/src/threadq.c, score/src/threadqdequeue.c, score/src/threadqdequeuefifo.c, score/src/threadqdequeuepriority.c, score/src/threadqenqueue.c, score/src/threadqenqueuefifo.c, score/src/threadqenqueuepriority.c, score/src/threadqextract.c, score/src/threadqextractfifo.c, score/src/threadqextractpriority.c, score/src/threadqextractwithproxy.c, score/src/threadqfirst.c, score/src/threadqfirstfifo.c, score/src/threadqfirstpriority.c, score/src/threadqflush.c, score/src/threadqrequeue.c, score/src/threadstackallocate.c, score/src/threadstartmultitasking.c, score/src/watchdog.c, score/src/watchdogadjust.c, score/src/watchdoginsert.c, score/src/watchdogremove.c, score/src/watchdogtickle.c: Remove /*PAGE markers which were interpreted by a long dead print script. | ||||
* | 2008-12-17 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2008-12-17 | 1 | -7/+5 |
| | | | | | | | | | | | | | * sapi/include/rtems/extension.h, sapi/include/rtems/io.h, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c, score/include/rtems/score/mpci.h, score/include/rtems/score/object.h, score/include/rtems/score/thread.h, score/include/rtems/score/tod.h, score/include/rtems/score/userext.h, score/include/rtems/score/wkspace.h, score/src/coretod.c, score/src/mpci.c, score/src/object.c, score/src/thread.c, score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and SuperCore Handler initialization routines to directly pull parameters from configuration table. | ||||
* | Convert to "bool". | Ralf Corsepius | 2008-09-04 | 1 | -2/+2 |
* | 2007-12-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 2007-12-19 | 1 | -2/+1 |
| | | | | | | | * sapi/src/extension.c, sapi/src/extensioncreate.c, sapi/src/extensiondelete.c, sapi/src/extensionident.c: Extension Manager clean up. Update object id switches to new pattern. Catch some NULL parameter errors. | ||||
* | 2005-01-28 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2005-01-28 | 1 | -0/+4 |
| | | | | | | | | * sapi/src/debug.c, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/extensioncreate.c, sapi/src/extensiondelete.c, sapi/src/extensionident.c, sapi/src/fatal.c, sapi/src/io.c, sapi/src/itronapi.c, sapi/src/posixapi.c, sapi/src/rtemsapi.c: Include config.h. | ||||
* | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 1 | -1/+1 |
| | | | | | | | | * sapi/include/confdefs.h, sapi/include/rtems/config.h, sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h, sapi/include/rtems/init.h, sapi/include/rtems/io.h, sapi/src/exinit.c, sapi/src/extension.c, sapi/src/fatal.c, sapi/src/io.c: Convert to using c99 fixed size types. | ||||
| | | | | | | | | | | | | * include/confdefs.h, include/rtems/config.h, include/rtems/extension.h, include/rtems/fatal.h, include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h, include/rtems/sptables.h, include/rtems/sptables.h.in, inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c, src/exinit.c, src/extension.c, src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c, src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license changed. | ||||
* | 2002-07-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-07-01 | 1 | -4/+8 |
| | | | | | | | | | | | | | | | | | | | | | * Mega patch merge to change the format of the object IDs to loosen the dependency between the SCORE and the various APIs. There was considerable work to simplify the object name management and it appears that the name_table field is no longer needed. This patch also includes the addition of the internal mutex which is currently only used to protect some types of allocation and deallocation. This significantly can reduce context switch latency under certain circumstances. In particular, some heap/region operations were O(n) and had dispatching disabled. This should help enormously. With this merge, the patch is not as clean as it should be. In particular, the documentation has not been modified to reflect the new object ID layout, the IDs in the test screens are not updated, and _Objects_Get_information needs to be a real routine not inlined. As part of this patch a lot of MP code for thread/proxy blocking was made conditional and cleaned up. * include/confdefs.h, src/exinit.c, src/extension.c, src/itronapi.c, src/posixapi.c, src/rtemsapi.c: Modified as part of above. | ||||
* | 2001-03-15 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-03-15 | 1 | -118/+1 |
| | | | | | | | * src/extension.c: Split to reduce minimum code size per PR134. * src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c: New files. src/Makefile.am: Modified to reflect above. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | posix support initially added | Joel Sherrill | 1995-09-26 | 1 | -2/+2 |
* | The word "RTEMS" almost completely removed from the core. | Joel Sherrill | 1995-09-11 | 1 | -13/+17 |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Configuration Table Template file added and all tests modified to use this. All gvar.h and conftbl.h files removed from test directories. Configuration parameter maximum_devices added. Core semaphore and mutex handlers added and RTEMS API Semaphore Manager updated to reflect this. Initialization sequence changed to invoke API specific initialization routines. Initialization tasks table now owned by RTEMS Tasks Manager. Added user extension for post-switch. Utilized user extensions to implement API specific functionality like signal dispatching. Added extensions to the System Initialization Thread so that an API can register a function to be invoked while the system is being initialized. These are largely equivalent to the pre-driver and post-driver hooks. Added the Modules file oar-go32_p5, modified oar-go32, and modified the file make/custom/go32.cfg to look at an environment varable which determines what CPU model is being used. All BSPs updated to reflect named devices and clock driver's IOCTL used by the Shared Memory Driver. Also merged clock isr into main file and removed ckisr.c where possible. Updated spsize to reflect new and moved variables. Makefiles for the executive source and include files updated to show break down of files into Core, RTEMS API, and Neither. Header and inline files installed into subdirectory based on whether logically in the Core or a part of the RTEMS API. | ||||
* | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 1995-08-23 | 1 | -1/+2 |
| | | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. | ||||
* | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1995-08-23 | 1 | -10/+13 |
| | | | | | | both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | ||||
* | + Added object type field to object id. | Joel Sherrill | 1995-08-18 | 1 | -0/+1 |
| | | | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. + Added parameter "object class" to calls to Initialize Information | ||||
* | Initial revision | Joel Sherrill | 1995-05-11 | 1 | -0/+156 |
