Updates #3053.
Make the initialization of the per-CPU data optional.
Change license to BSD-2-Clause according to file history and
re-licensing agreement.
Update #3053.
Adjust group identifier and names to be in line with a common pattern.
Use common phrases for the group and file brief descriptions.
Update #3706.
Add the _Copyright_Notice to a special linker set to prevent a garbage
collection of this item.
#ifdef HAVE_CONFIG_H
#include "config.h"
#endif
The work area initialization was done by the BSP through
bsp_work_area_initialize(). This approach predated the system
initialization through the system initialization linker set. The
workspace and C program heap were unconditionally initialized. The aim
is to support RTEMS application configurations which do not need the
workspace and C program heap. In these configurations, the workspace
and C prgram heap should not get initialized.
Change all bsp_work_area_initialize() to implement _Memory_Get()
instead. Move the dirty memory, sbrk(), per-CPU data, workspace, and
malloc() heap initialization into separate system initialization steps.
This makes it also easier to test the individual initialization steps.
This change adds a dependency to _Heap_Extend() to all BSPs. This
dependency will be removed in a follow up change.
Update #3838.
Use a self-contained recursive mutex for API_Mutex_Control. The API
mutexes are protected against asynchronous thread cancellation.
Add dedicated mutexes for libatomic and TOD.
Close #2629.
Close #2630.
Resurrect RTEMS_LINKER_SET_BEGIN() and RTEMS_LINKER_SET_END().
Add new macros RTEMS_LINKER_SET_ITEM_COUNT(),
RTEMS_LINKER_SET_IS_EMPTY(), and
RTEMS_LINKER_SET_FOREACH().
Remove confusing RTEMS_LINKER_SET_ASSIGN_BEGIN() and
RTEMS_LINKER_SET_ASSIGN_END().
Fix RTEMS_LINKER_SET_SIZE() to return the size in characters as
specified by the documentation.
Update #2408.
Update #2790.
Update #2408.
Update #2790.
The _Objects_Information_table is statically initialized. So, we can
make it read-only.
Create implementation header file.
Update #2555.
Use a red-black tree instead of delta chains.
Close #2344.
Update #2554.
Update #2555.
Close #2606.
Delete SCORE_INIT. This finally removes the
some.h:
#ifndef SOME_XYZ_EXTERN
#define SOME_XYZ_EXTERN extern
#endif
SOME_XYZ_EXTERN type xyz;
some_xyz.c:
#include <some.h>
pattern in favour of
some.h:
extern type xyz;
some_xyz.c
#include <some.h>
type xyz;
Update #2559.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
This allows a more fine grained rtems_initialize_data_structures().
Update #2408.
The --enable-drvmgr configure option controls the driver manager startup
and not if the driver manager is present or not. Presence of the driver
manager is determined by the architecture (only available on sparc so
far).
This reverts commit 61bbf9194ff4bdbc1b48e6ac9919c02b358e5701.
Make rtems_initialize_data_structures(),
rtems_initialize_before_drivers() and rtems_initialize_device_drivers()
static. Rename rtems_initialize_start_multitasking() to
rtems_initialize_executive() and call the registered system
initialization handlers in this function. Add system initialization API
available via #include <rtems/sysinit.h>. Update the documentation
accordingly.
This is no functional change, only the method to call the existing
initialization routines changes. Instead of direct function calls a
table of function pointers contained in the new RTEMS system
initialization linker set is used. This table looks like this (the
actual addresses depend on the target).
nm *.exe | grep _Linker | sort
0201a2d0 D _Linker_set__Sysinit_begin
0201a2d0 D _Linker_set__Sysinit_bsp_work_area_initialize
0201a2d4 D _Linker_set__Sysinit_bsp_start
0201a2d8 D _Linker_set__Sysinit_rtems_initialize_data_structures
0201a2dc D _Linker_set__Sysinit_bsp_libc_init
0201a2e0 D _Linker_set__Sysinit_rtems_initialize_before_drivers
0201a2e4 D _Linker_set__Sysinit_bsp_predriver_hook
0201a2e8 D _Linker_set__Sysinit_rtems_initialize_device_drivers
0201a2ec D _Linker_set__Sysinit_bsp_postdriver_hook
0201a2f0 D _Linker_set__Sysinit_end
Add test sptests/spsysinit01.
Update #2408.
Update #2408.
Update #2408.
Update #2408.
Close #2477.
Replace timestamp implementation with FreeBSD bintime and timecounters.
New test sptests/sptimecounter02.
Update #2271.
This simplifies the RTEMS initialization and helps to avoid a memory
overhead. The workspace demands of the IO manager were not included in
the <rtems/confdefs.h> workspace size estimate. This is also fixed as a
side-effect.
Update documentation and move "Specifying Application Defined Device
Driver Table" to the section end. This sub-section is not that
important for the user. Mentioning this at the beginning may lead to
confusion.
Enable pthread_once() for all configurations. The pthread_once()
function is one means to initialize POSIX keys. Another use case is the
C++ support.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
SMP must be initialized in order to know the current set of
cores available. Without this, you cannot initialize the
default cpu_set_t associated with Classic API tasks and
POSIX threads.
Rename _SMP_Request_other_cores_to_perform_first_context_switch() into
_SMP_Request_start_multitasking() since this requests now a multitasking
start on all configured and available processors. The name corresponds
_Thread_Start_multitasking() and
_SMP_Start_multitasking_on_secondary_processor() actions issued in
response to this request. Move in source file to right place.
Rename PER_CPU_STATE_READY_TO_BEGIN_MULTITASKING into
PER_CPU_STATE_READY_TO_START_MULTITASKING.
Rename PER_CPU_STATE_BEGIN_MULTITASKING into
PER_CPU_STATE_REQUEST_START_MULTITASKING.
Rename _SMP_Request_other_cores_to_shutdown() into
_SMP_Request_shutdown().
Add a per-CPU state lock to protect all changes. This was necessary to
offer a controlled shutdown of the system (atomic read/writes alone are
not sufficient for this kind of synchronization).
Add documentation for Per_CPU_State.
Delete debug output.
New tests smptests/smpfatal01 and smptests/smpfatal02.
Collect SMP implementation specific parts in the
<rtems/score/smpimpl.h> header file.
Do not return to BSP context in the exit() shutdown path. This makes it
possible to re-use the initialization stack. It can be used for the
interrupt stack for example. On targets with a small RAM this is a
considerable benefit.
This change eliminates also some special cases and simplifies the code.
Delete _Thread_Set_global_exit_status(),
_Thread_Get_global_exit_status() and _Thread_Stop_multitasking().
Delete _Priority_bit_map_Handler_initialization() and rely on BSS
initialization. Move definition of _Priority_Major_bit_map and
_Priority_Bit_map to separate file. Move definition of __log2table also
to this file.
Add context parameter to _Thread_Start_multitasking() and use this
function in rtems_smp_secondary_cpu_initialize(). This avoids
duplication of code.
Fix missing floating point context initialization in
rtems_smp_secondary_cpu_initialize(). Now performed via
_Thread_Start_multitasking().
Nothing happened between the SYSTEM_STATE_BEGIN_MULTITASKING to
SYSTEM_STATE_UP transition.
Move implementation specific parts of mpci.h into new header file
mpciimpl.h. The mpci.h contains now only the application visible API.
