path: root/cpukit/sapi/src/cpucounterconverter.c (follow)
* Use RTEMS_SYSINIT_ORDER_LAST_BUT_5Sebastian Huber2020-02-041-1/+1
| | | | | | | | Use RTEMS_SYSINIT_ORDER_LAST_BUT_5 instead of RTEMS_SYSINIT_ORDER_LAST to allow applications and support functions to place system initialization handlers behind the standard handlers. Update #3838.
* Convert CPU counter ticks to/from sbintime_tSebastian Huber2018-12-031-2/+20
| | | | | The sbintime_t is an efficient time format. Add the ability to convert CPU counter ticks to/from sbintime_t.
* Add _CPU_Counter_frequency()Sebastian Huber2018-06-151-3/+15
| | | | | | | | | | Add rtems_counter_frequency() API function. Use it to initialize the counter value converter via the new system initialization step (RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation and the counter converter. It avoids an unnecessary pull in of the 64-bit integer division from libgcc. Update #3456.
* score: Add CPU counter supportSebastian Huber2014-02-141-0/+39
Add a CPU counter interface to allow access to a free-running counter. It is useful to measure short time intervals. This can be used for example to enable profiling of critical low-level functions. Add two busy wait functions rtems_counter_delay_ticks() and rtems_counter_delay_nanoseconds() implemented via the CPU counter.
