path: root/cpukit/sapi/src/chainappendnotify.c (follow)
* sapi: Canonicalize @defgroup and @file commentsSebastian Huber2020-12-021-2/+3
| | | | | | | Adjust group identifier and names to be in line with a common pattern. Use common phrases for the group and file brief descriptions. Update #3706.
* 2010-08-24 Sebastian Huber <sebastian.huber@embedded-brains.de>Sebastian Huber2010-08-241-0/+44
PR 1673/cpukit * sapi/src/chainappendnotify.c, sapi/src/chaingetnotify.c, sapi/src/chaingetwait.c, sapi/src/chainprependnotify.c: New files. * sapi/Makefile.am: Reflect changes above. * sapi/include/rtems/chain.h: Declare rtems_chain_append_with_notification(), rtems_chain_prepend_with_notification(), rtems_chain_get_with_notification(), and rtems_chain_get_with_wait(). * sapi/inline/rtems/chain.inl: Define rtems_chain_append_with_empty_check(), rtems_chain_prepend_with_empty_check(), and rtems_chain_get_with_empty_check().
