path: root/cpukit/sapi/src/Makefile.am (unfollow)
2002-12-092002-12-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-32/+0
* include/Makefile.am: Remove. * inline/Makefile.am: Remove. * macros/Makefile.am: Remove. * src/Makefile.am: Remove. * Makefile.am: Merge-in removed Makefile.ams.
2002-08-012002-08-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+5
* src/Makefile.am: Add libsrtems.a.
2002-07-222002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* src/Makefile.am: Use .$(OBJEXT) instead of .o.
2002-07-042002-07-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* Jump table for single entry point removed. * include/rtems/directives.h, src/entrytable.c: Removed. * include/Makefile.am, src/Makefile.am, src/exinit.c: Modified to reflect above.
2002-06-172002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-4/+4
* Include $(top_srcdir)/automake/*.am.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * inline/Makefile.am: Remove AUTOMAKE_OPTIONS. * macros/Makefile.am: Remove AUTOMAKE_OPTIONS. * src/Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-152001-03-15 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-2/+4
* src/extension.c: Split to reduce minimum code size per PR134. * src/extensioncreate.c, src/extensiondelete.c, src/extensionident.c: New files. src/Makefile.am: Modified to reflect above.
2001-12-192001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* optman/Makefile.am: Add multilib support. * src/Makefile.am: Add multilib support.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-2/+1
2000-02-08Patches rtems-rc-20000204-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
that contains: * Removes remaining (now illegal) references to $(SRC) from a couple of Makefile.ams * Removes duplicate AC_CONFIG_SUBDIRS macro from c/configure.in * Moves ENABLE_LIBCDIR into RTEMS_PROG_C[C|XX]_FOR_TARGET (hides LIBCDIR from most configure scripts, i.e. LIBCDIR becomes less visible) * Adds RTEMS_PROG_C[C|XX]_FOR_TARGET and RTEMS_CANONICALIZE_TOOLS to libbsp/*/configure.ins (A minor bug in previous implementations, which only has an impact when switching to GNU/Cygnus canonicalization) * Cleans up several bogus comments. * Removes MKLIB * Switches the version number to 4.5.0 (for testing version number handling)
1999-11-23Patch rtems-rc-19991117-11.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+28
to convert the libc directory to automake and "dozens of small fixes for Makefile.ins/configure.ins below c/src/lib."
