* libmisc/dummy/dummy-networking.c: New.
* libmisc/dummy/dummy.c, libmisc/Makefile.am: Move
trhe networking configuration into a separate file so
configuration varations do not cause conflicts.
* score/inline/rtems/score/object.inl,
score/include/rtems/score/object.h: Remove warnings.
* score/inline/rtems/score/object.inl: Add _Chain_First,
_Chain_Last, _Chain_Mext, and _Chain_Previous.
* sapi/inline/rtems/chain.inl: Add rtems_chain_first,
rtems_chain_last, rtems_chain_mext, and rtems_chain_previous.
* libblock/include/rtems/diskdevs.h: Remove the bdbuf pool id and
block_size_log2. Add media_block_size.
* libblock/src/diskdevs.c: Remove size restrictions on block
size. Add media block size initialisation. Remove comment to clean
up the bdbuf cache.
* libblock/src/blkdev.c: Remove references to
block_size_log2. Allow any block size.
* libblock/include/rtems/bdbuf.h, libblock/src/bdbuf.c: Remove all
references to pools and make the cache handle demand driver
variable buffer size allocation. Added worker threads support the
swapout task.
* sapi/include/confdefs.h: Updated the bdbuf configutation.
PR 1340/cpukit
* sapi/inline/rtems/chain.inl: Add rtems_chain_initialize to public
chain API.
PR 1336/cpukit
* sapi/inline/rtems/chain.inl: Add rtems_chain_prepend_unprotected and
rtems_chain_append_unprotected.
* cpukit/libcsupport/include/chain.h: Removed. Use the SAPI
interface that is supported.
* cpukit/libcsupport/Makefile.am,
cpukit/libcsupport/preinstall.am: Remove chain.h header
references.
* cpukit/sapi/include/rtems/chain.h,
cpukit/sapi/inline/rtems/chain.inl: New. A supported chains
interface.
* cpukit/sapi/Makefile.am, cpukit/sapi/preinstall.am: Updated to
include the new chains interface.
* cpukit/libfs/src/imfs/imfs.h,
cpukit/libfs/src/imfs/imfs_creat.c,
cpukit/libfs/src/imfs/imfs_debug.c,
cpukit/libfs/src/imfs/imfs_directory.c,
cpukit/libfs/src/imfs/imfs_fsunmount.c,
cpukit/libfs/src/imfs/imfs_getchild.c,
cpukit/libfs/src/imfs/imfs_load_tar.c,
cpukit/libfs/src/imfs/imfs_rmnod.c,
cpukit/libfs/src/imfs/memfile.c,
cpukit/libfs/src/nfsclient/src/nfs.c,
cpukit/libcsupport/include/rtems/libio.h,
cpukit/libcsupport/src/malloc_deferred.c,
cpukit/libcsupport/src/mount.c,
cpukit/libcsupport/src/privateenv.c,
cpukit/libcsupport/src/unmount.c: Change to the new chains
interface.
* cpukit/libcsupport/src/malloc_boundary.c: Remove warning.
* include/confdefs.h, include/rtems/config.h,
include/rtems/extension.h, include/rtems/fatal.h,
include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h,
include/rtems/sptables.h, include/rtems/sptables.h.in,
inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c,
src/exinit.c, src/extension.c, src/extensioncreate.c,
src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c,
src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license
changed.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* Include $(top_srcdir)/automake/*.am.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
