* Makefile.am, preinstall.am: Added statvfs.h.
* libcsupport/Makefile.am: Add statvfs.c.
* libcsupport/include/sys/statvfs.h, libcsupport/src/statvfs.c:
New.
* libcsupport/include/rtems/libio.h: Add a file system handler for
the statvfs call.
* libfs/src/devfs/devfs_init.c, libfs/src/dosfs/msdos_init.c,
libfs/src/imfs/imfs_init.c, libfs/src/nfsclient/src/nfs.c: Set the
statvfs handler to NULL.
* include/rtems/fs.h: Add a second node access field for the RFS
file system to hold a directory offset while the existing field
holds the inode number. This save a rescan of the directory when
working with directories.
* libblock/include/rtems/bdbuf.h: Added references and user fields
to the buffer descriptor.
* libblock/src/bdbuf.c: Added dynamic buffer support for different
block sizes. Fixed a number of bugs.
* libblock/src/blkdev.c: Release the disk device on an error.
* libblock/src/diskdevs.c: Set the block size to the media block
size during initialisation of the disk device.
* libblock/src/flashdisk.c, libblock/src/nvdisk.c,
libblock/src/ramdisk.c: Updated the drivers to handle variable
block sizes.
* libfs/src/dosfs/fat.c, libfs/src/dosfs/fat.h: Release any
buffers when an error occurs. The FAT buffer layer hangs onto a
single buffer while mounted. This should be fixed.
* sapi/inline/rtems/chain.inl: Added rtems_chain_set_off_chain,
rtems_chain_is_node_off_chain, and rtems_chain_previous.
* score/inline/rtems/score/chain.inl: Added _Chain_Set_off_chain,
and _Chain_Is_node_off_chain.
* libmisc/shell/main_ln.c, libmisc/shell/main_mknod.c,
libmisc/shell/mknod-pack_dev.c, libmisc/shell/mknod-pack_dev.h:
New shell commands.
* libmisc/Makefile.am, libmisc/shell/shellconfig.h: Added ln and
mknod commands.
* libmisc/shell/hexdump-display.c: Fixed the reopen bug which
showed up as a free with a bad pointer.
* libmisc/shell/main_mount.c: List the user adding file system
when listing the available file systems to mount.
* libmisc/shell/utils-cp.c: Remove the fixed static copy buffer
and use a large dynamic buffer.
* score/inline/rtems/score/address.inl, score/src/coremsgsubmit.c,
score/src/objectallocate.c, score/src/objectfree.c: Remove
warnings.
* sapi/include/rtems/extension.h, sapi/src/extensiondelete.c,
sapi/src/extensionident.c, sapi/src/extensioncreate.c,
sapi/inline/rtems/extension.inl, score/include/rtems/score/userext.h,
score/src/userextthreaddelete.c, score/src/userext.c,
score/src/userextthreadcreate.c, score/src/userextremoveset.c,
score/src/userextthreadbegin.c, score/src/userextaddset.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/userextthreadrestart.c: Documentation. The types
User_extensions_routine and rtems_extension are now deprecated.
Removed unused types User_extensions_thread_post_switch_extension and
rtems_task_post_switch_extension. Renamed _User_extensions_Add_API_set()
in _User_extensions_Add_set(). Renamed _User_extensions_Add_set() in
_User_extensions_Add_set_with_table().
* score/src/userextaddapiset.c: Removed file.
* score/Makefile.am: Update.
* libmisc/dummy/dummy-networking.c: New.
* libmisc/dummy/dummy.c, libmisc/Makefile.am: Move
trhe networking configuration into a separate file so
configuration varations do not cause conflicts.
* score/inline/rtems/score/object.inl,
score/include/rtems/score/object.h: Remove warnings.
* score/inline/rtems/score/object.inl: Add _Chain_First,
_Chain_Last, _Chain_Mext, and _Chain_Previous.
* sapi/inline/rtems/chain.inl: Add rtems_chain_first,
rtems_chain_last, rtems_chain_mext, and rtems_chain_previous.
* libblock/include/rtems/diskdevs.h: Remove the bdbuf pool id and
block_size_log2. Add media_block_size.
* libblock/src/diskdevs.c: Remove size restrictions on block
size. Add media block size initialisation. Remove comment to clean
up the bdbuf cache.
* libblock/src/blkdev.c: Remove references to
block_size_log2. Allow any block size.
* libblock/include/rtems/bdbuf.h, libblock/src/bdbuf.c: Remove all
references to pools and make the cache handle demand driver
variable buffer size allocation. Added worker threads support the
swapout task.
* sapi/include/confdefs.h: Updated the bdbuf configutation.
PR 1340/cpukit
* sapi/inline/rtems/chain.inl: Add rtems_chain_initialize to public
chain API.
PR 1336/cpukit
* sapi/inline/rtems/chain.inl: Add rtems_chain_prepend_unprotected and
rtems_chain_append_unprotected.
* cpukit/libcsupport/include/chain.h: Removed. Use the SAPI
interface that is supported.
* cpukit/libcsupport/Makefile.am,
cpukit/libcsupport/preinstall.am: Remove chain.h header
references.
* cpukit/sapi/include/rtems/chain.h,
cpukit/sapi/inline/rtems/chain.inl: New. A supported chains
interface.
* cpukit/sapi/Makefile.am, cpukit/sapi/preinstall.am: Updated to
include the new chains interface.
* cpukit/libfs/src/imfs/imfs.h,
cpukit/libfs/src/imfs/imfs_creat.c,
cpukit/libfs/src/imfs/imfs_debug.c,
cpukit/libfs/src/imfs/imfs_directory.c,
cpukit/libfs/src/imfs/imfs_fsunmount.c,
cpukit/libfs/src/imfs/imfs_getchild.c,
cpukit/libfs/src/imfs/imfs_load_tar.c,
cpukit/libfs/src/imfs/imfs_rmnod.c,
cpukit/libfs/src/imfs/memfile.c,
cpukit/libfs/src/nfsclient/src/nfs.c,
cpukit/libcsupport/include/rtems/libio.h,
cpukit/libcsupport/src/malloc_deferred.c,
cpukit/libcsupport/src/mount.c,
cpukit/libcsupport/src/privateenv.c,
cpukit/libcsupport/src/unmount.c: Change to the new chains
interface.
* cpukit/libcsupport/src/malloc_boundary.c: Remove warning.
* include/confdefs.h, include/rtems/config.h,
include/rtems/extension.h, include/rtems/fatal.h,
include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h,
include/rtems/sptables.h, include/rtems/sptables.h.in,
inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c,
src/exinit.c, src/extension.c, src/extensioncreate.c,
src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c,
src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license
changed.
* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* Include $(top_srcdir)/automake/*.am.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
