line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3220.
Use a self-contained recursive mutex for API_Mutex_Control. The API
mutexes are protected against asynchronous thread cancellation.
Add dedicated mutexes for libatomic and TOD.
Close #2629.
Close #2630.
The previous rtems_panic() implementation was quite heavy weight. It
depended on _exit() which calls the global destructors. It used
fprintf(stderr, ...) for output which depends on an initialized console
device and the complex fprintf().
Introduce a new fatal source RTEMS_FATAL_SOURCE_PANIC for rtems_panic()
and output via vprintk().
Update #3244.
Provide functions to get the version string, major, minor and revision
numbers and the version control identifer that is a unique tag for
the version control system.
Update #3199.
Update #3170.
Update #3199.
Reject non-positive CONFIGURE_MICROSECONDS_PER_TICK values.
Move it from the configuration to a separate variable.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
A non-integer clock ticks per second value may lead to inaccurate time
format conversions.
Update #3117.
Update #3182.
This value is frequently used. Avoid the function call overhead and the
integer division at run-time.
Update #3117.
Update #3182.
Update #2674.
Close #3112.
Close #3113.
Close #3114.
Close #3115.
Close #3116.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
Remove the OBJECTS_UNLIMITED_OBJECTS flag for the memory size
configuration.
Update #3105.
The EDF SMP scheduler supports simple thread processor affinities
(see #3059) with a small run-time overhead. The current default SMP
scheduler lacks support for thread processor affinities at all. The EDF
SMP scheduler offers a good feature set for most applications. So, use
it by default. Run-time libraries like libgomp, MTAPI, work stealing
schedulers, language interpreters (e.g. Erlang virtual machine),
maintainence of per-processor data (e.g. Universal Memory Allocator
(UMA)), etc. use a one-to-one thread processor affinity for example.
Update #3063.
Update #3059.
Update #3056.
Do not use the processor count to determine if SMP is enabled. Instead
use a dedicated configuration option. Enable SMP by default in SMP
configurations.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
Bug introduced by f778b7f3f177a39505aeea61206e95fc54f875be.
Update #3001.
Update #3001.
Enable the SMP configuration by default in case SMP is enabled. Add
configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it
explicitly.
otherwise.
Update #3001.
Update #2859.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Close #2895.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
Add configuration option CONFIGURE_MAXIMUM_THREAD_NAME_SIZE.
Update #2858.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Rename _Scheduler_Assignments into _Scheduler_Initial_assignments to
make it clear that they may not reflect the run-time scheduler
assignment.
Update #2797.
Update #2556.
This helps to detect
* double insert, append, prepend errors, and
* get from empty chain errors.
The _RBTree_Find() is no longer used in the score. Move it to sapi and
make it rtems_rbtree_find(). Move corresponding types and support
functions to sapi.
The _RBTree_Insert() is no longer used in the score. Move it to sapi
and make it rtems_rbtree_insert().
Do not hide network file systems if RTEMS_NETWORKING is not defined,
since they may be provided by the LibBSD.
Account for the heap minimum block size.
of this patch set.
