POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
Remove the OBJECTS_UNLIMITED_OBJECTS flag for the memory size
configuration.
Update #3105.
The EDF SMP scheduler supports simple thread processor affinities
(see #3059) with a small run-time overhead. The current default SMP
scheduler lacks support for thread processor affinities at all. The EDF
SMP scheduler offers a good feature set for most applications. So, use
it by default. Run-time libraries like libgomp, MTAPI, work stealing
schedulers, language interpreters (e.g. Erlang virtual machine),
maintainence of per-processor data (e.g. Universal Memory Allocator
(UMA)), etc. use a one-to-one thread processor affinity for example.
Update #3063.
Update #3059.
Update #3056.
Do not use the processor count to determine if SMP is enabled. Instead
use a dedicated configuration option. Enable SMP by default in SMP
configurations.
Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail
otherwise.
Update #3001.
Bug introduced by f778b7f3f177a39505aeea61206e95fc54f875be.
Update #3001.
Update #3001.
Enable the SMP configuration by default in case SMP is enabled. Add
configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it
explicitly.
otherwise.
Update #3001.
Update #2859.
Rename CONFIGURE_SMP_MAXIMUM_PROCESSORS to CONFIGURE_MAXIMUM_PROCESSORS
since the SMP part is superfluous.
Update #2894.
Close #2895.
Enable the SMP support if CONFIGURE_SMP_MAXIMUM_PROCESSORS > 1.
Update #2893.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
Add configuration option CONFIGURE_MAXIMUM_THREAD_NAME_SIZE.
Update #2858.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
Rename _Scheduler_Assignments into _Scheduler_Initial_assignments to
make it clear that they may not reflect the run-time scheduler
assignment.
Update #2797.
Update #2556.
This helps to detect
* double insert, append, prepend errors, and
* get from empty chain errors.
The _RBTree_Find() is no longer used in the score. Move it to sapi and
make it rtems_rbtree_find(). Move corresponding types and support
functions to sapi.
The _RBTree_Insert() is no longer used in the score. Move it to sapi
and make it rtems_rbtree_insert().
Do not hide network file systems if RTEMS_NETWORKING is not defined,
since they may be provided by the LibBSD.
Account for the heap minimum block size.
of this patch set.
The priority values are only valid within a scheduler instance. Thus,
the maximum priority value must be defined per scheduler instance. The
first scheduler instance defines PRIORITY_MAXIMUM. This implies that
RTEMS_MAXIMUM_PRIORITY and POSIX_SCHEDULER_MAXIMUM_PRIORITY are only
valid for threads of the first scheduler instance. Further
API/implementation changes are necessary to fix this.
Update #2556.
Update #2494.
Update #2555.
Account for maximum message size alignment. Simplify
_CORE_message_queue_Initialize().
Account for the terminating null character. Use _POSIX_PATH_MAX instead
of NAME_MAX according to _POSIX_Semaphore_Manager_initialization() and
_POSIX_Message_queue_Manager_initialization().
Start with a copy of the Priority SMP scheduler implementation.
Update #2510.
The mq_open() function returns a descriptor to a POSIX message queue
object identified by a name. This is similar to sem_open(). In
contrast to the POSIX semaphore the POSIX message queues use a separate
object for the descriptor. This extra object is superfluous, since the
object identifier can be used directly for this purpose, just like for
the semaphores.
Update #2702.
Update #2555.
Make the id the first parameter since usual callers get the object
identifier as the first parameter themself.
Extension create and delete is protected by the object allocator lock.
Update #2555.
This function is not used in the score.
Update #2555.
Update #2555.
Update #2555.
Update #2555.
Update #2555.
Update #2555.
Update #2555.
