* inline/Makefile.am: Remove.
* macros/Makefile.am: Remove.
* src/Makefile.am: Remove.
* Makefile.am: Merge-in removed Makefile.ams.
* Jump table for single entry point removed.
* include/rtems/directives.h, src/entrytable.c: Removed.
* include/Makefile.am, src/Makefile.am, src/exinit.c: Modified to
reflect above.
* Mega patch merge to change the format of the object IDs to
loosen the dependency between the SCORE and the various APIs.
There was considerable work to simplify the object name management
and it appears that the name_table field is no longer needed.
This patch also includes the addition of the internal mutex
which is currently only used to protect some types of allocation
and deallocation. This significantly can reduce context
switch latency under certain circumstances. In particular,
some heap/region operations were O(n) and had dispatching
disabled. This should help enormously. With this merge,
the patch is not as clean as it should be. In particular,
the documentation has not been modified to reflect the new object
ID layout, the IDs in the test screens are not updated, and
_Objects_Get_information needs to be a real routine not inlined.
As part of this patch a lot of MP code for thread/proxy blocking
was made conditional and cleaned up.
* include/confdefs.h, src/exinit.c, src/extension.c, src/itronapi.c,
src/posixapi.c, src/rtemsapi.c: Modified as part of above.
* Include $(top_srcdir)/automake/*.am.
* Per PR126, configuration structures now match docs.
* include/rtems/config.h: Use public data types.
* PR132 requested some tinkering ot lower memory.
* include/confdefs.h: Lowered footprint of device driver table
and statically configure user extensions. Now if no static
extensions are configured, then the table is not instantiated.
* inline/Makefile.am: Remove AUTOMAKE_OPTIONS.
* macros/Makefile.am: Remove AUTOMAKE_OPTIONS.
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* include/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* inline/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* macros/rtems/Makefile.am: Use 'PREINSTALL_FILES ='.
* include/confdefs.h: Fix real-time clock support.
* include/Makefile.am, include/rtems/Makefile.am,
inline/rtems/Makefile.am, macros/rtems/Makefile.am:
* include/confdefs.h: define CONFIGURE_NEWLIB_EXTENSION 0 if not
using NEWLIB, cleanup related comment.
* include/confdefs.h: include cpuopts.h, replace stubdr w/ devnull.
effects in RTEMS source code.
* include/confdefs.h: Replaced include of <sys/siginfo.h> with
<signal.h> since that file no longer exists.
* include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0
if there is no Classic API Initialization Tasks Table defined.
* include/confdefs.h: Modified code that accounts for initialization
task/threads with greater than minimum stack sizes so it would
compile even if optional APIs are disabled.
* include/confdefs.h: Account for initialization tasks and
threads which use larger than minimum stack sizes.
* include/rtems/io.h (rtems_driver_address_table): Added "_entry"
to all names.
* src/io.c: Accounted for above.
<elkolli@crf.canon.fr> to add support for the mbx860_005b.
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
for RTEMS.
BSP needs to be eliminated.
parameter.
CONFIGURE_MAXIMUM_POSIX_SEMAPHORES.
CONFIGURE_POSIX_INIT_THREAD_STACK_SIZE because in POSIX they are threads.
of POSIX Init thread to be user configured.
are:
it work.
used to calculate the amount of memory used by tasks whether the
POSIX API is enabled or disabled.
+ POSIX threads
+ Ada tasks
+ POSIX threads API support
+ POSIX condition variables
+ POSIX keys (still do not account for data fields)
+ POSIX mutexes
+ POSIX queued signals
+ added macro for extra memory for task stacks
+ default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+ extra memory for Ada task stacks
memory requirements.
Also added variable to tell libio how many file descriptors to allocate.
