used to calculate the amount of memory used by tasks whether the
POSIX API is enabled or disabled.
+ POSIX threads
+ Ada tasks
+ POSIX threads API support
+ POSIX condition variables
+ POSIX keys (still do not account for data fields)
+ POSIX mutexes
+ POSIX queued signals
+ added macro for extra memory for task stacks
+ default value for CONFIGURE_MAXIMUM_FAKE_ADA_TASKS
+ extra memory for Ada task stacks
memory requirements.
Also added variable to tell libio how many file descriptors to allocate.
by newlib.
the workspace by default.
for GNAT. It was the number of Ada tasks when in fact the run-time
only required a single key.
Also added the CONFIGURE_MAXIMUM_FAKE_ADA_TASKS constant to account
for resources allocated for each non-Ada task/thread which invokes
the Ada run-time implicitly through an Ada call.
be resolved.
RTEMS initialization tasks.
only the rtems api don't have to include it.
in each thread which must be set when the post switch extension is to be run.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
