Update #2408.
Update #2502.
This avoids potential dead code in _Thread_Handler(). It gets rid of
the dangerous function pointer casts.
Update #2514.
Notepads where a feature of RTEMS' tasks that simply functioned in
the same way as POSIX keys or threaded local storage (TLS). They were
introduced well before per task variables, which are also deprecated,
and were barely used in favor of their POSIX alternatives.
In addition to their scarce usage, Notepads took up unnecessary memory.
For each task:
- 16 32-bit integers were allocated.
- A total of 64 bytes per task per thread.
This is especially critical in low memory and safety-critical applications.
They are also defined as uint32_t, and therefore are not guaranteed to
hold a pointer.
Lastly, they are not portable solutions for SMP and uniprocessor systems,
like POSIX keys and TLS.
updates #2493.
Make rtems_initialize_data_structures(),
rtems_initialize_before_drivers() and rtems_initialize_device_drivers()
static. Rename rtems_initialize_start_multitasking() to
rtems_initialize_executive() and call the registered system
initialization handlers in this function. Add system initialization API
available via #include <rtems/sysinit.h>. Update the documentation
accordingly.
This is no functional change, only the method to call the existing
initialization routines changes. Instead of direct function calls a
table of function pointers contained in the new RTEMS system
initialization linker set is used. This table looks like this (the
actual addresses depend on the target).
nm *.exe | grep _Linker | sort
0201a2d0 D _Linker_set__Sysinit_begin
0201a2d0 D _Linker_set__Sysinit_bsp_work_area_initialize
0201a2d4 D _Linker_set__Sysinit_bsp_start
0201a2d8 D _Linker_set__Sysinit_rtems_initialize_data_structures
0201a2dc D _Linker_set__Sysinit_bsp_libc_init
0201a2e0 D _Linker_set__Sysinit_rtems_initialize_before_drivers
0201a2e4 D _Linker_set__Sysinit_bsp_predriver_hook
0201a2e8 D _Linker_set__Sysinit_rtems_initialize_device_drivers
0201a2ec D _Linker_set__Sysinit_bsp_postdriver_hook
0201a2f0 D _Linker_set__Sysinit_end
Add test sptests/spsysinit01.
Update #2408.
Close #2477.
Close #2459.
This function is hard to support in alternative implementations. It has
no internal use case.
This function has no internal use case.
New test sptests/timecounter01.
Update #2271.
Simplify _RBTree_Insert() and _RBTree_Extract(). Remove more
superfluous NULL pointer checks. Change _RBTree_Is_root() to use only
the node. Add parent parameter to _RBTree_Sibling(). Delete
_RBTree_Grandparent() and _RBTree_Parent_sibling().
Simplify _RBTree_Find_control(). Avoid superfluous NULL pointer checks.
Only use the parent pointer, since this pointer is never NULL for nodes
which are part of a tree.
Rename functions from *_off_rbtree() to *_off_tree().
Remove compare function and is unique indicator from the control
structure. Rename RBTree_Compare_function to RBTree_Compare. Rename
rtems_rbtree_compare_function to rtems_rbtree_compare. Provide C++
compatible initializers. Add compare function and is unique indicator
to _RBTree_Find(), _RBTree_Insert(), rtems_rbtree_find() and
rtems_rbtree_insert(). Remove _RBTree_Is_unique() and
rtems_rbtree_is_unique(). Remove compare function and is unique
indicator from _RBTree_Initialize_empty() and
rtems_rbtree_initialize_empty().
Clustered/partitioned scheduling helps to control the worst-case
latencies in the system. The goal is to reduce the amount of shared
state in the system and thus prevention of lock contention. Modern
multi-processor systems tend to have several layers of data and
instruction caches. With clustered/partitioned scheduling it is
possible to honour the cache topology of a system and thus avoid
expensive cache synchronization traffic.
We have clustered scheduling in case the set of processors of a system
is partitioned into non-empty pairwise-disjoint subsets. These subsets
are called clusters. Clusters with a cardinality of one are partitions.
Each cluster is owned by exactly one scheduler instance.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
This simplifies the RTEMS initialization and helps to avoid a memory
overhead. The workspace demands of the IO manager were not included in
the <rtems/confdefs.h> workspace size estimate. This is also fixed as a
side-effect.
Update documentation and move "Specifying Application Defined Device
Driver Table" to the section end. This sub-section is not that
important for the user. Mentioning this at the beginning may lead to
confusion.
Provide support functions to print the begin/end of test message.
Provide a test fatal extension to print out profiling reports in the
future.
This partially reverts commit 1215fd4d9426a59d568560e9a485628560363133.
In order to support profiling of SMP locks and provide a future
compatible SMP locks API it is necessary to add an SMP lock destroy
function. Since the commit above adds an SMP lock to each chain control
we would have to add a rtems_chain_destroy() function as well. This
complicates the chain usage dramatically. Thus revert the patch above.
A global SMP lock for all chains is used to implement the protected
chain operations.
Advantages:
* The SAPI chain API is now identical on SMP and non-SMP
configurations.
* The size of the chain control is reduced and is then equal to the
Score chains.
* The protected chain operations work correctly on SMP.
Disadvantage:
* Applications using many different chains and the protected operations
may notice lock contention.
The chain control size drop is a huge benefit (SAPI chain controls are
66% larger than the Score chain controls). The only disadvantage is not
really a problem since these applications can use specific interrupt
locks and unprotected chain operations to avoid this issue.
Formerly POSIX keys were only enabled when POSIX threads
were enabled. Because they are a truly safe alternative
to per-task variables in an SMP system, they are being
enabled in all configurations.
Rename _Internal_error_Occurred() into _Terminate().
Rename rtems_internal_error_description() to
rtems_internal_error_text(). Rename rtems_fatal_source_description() to
rtems_fatal_source_text(). Rename rtems_status_code_description() to
rtems_status_text(). Remove previous implementation of
The user of the red-black tree container must now ensure that at most
one thread at once can access an instance.
Add ISR lock to chain control for proper SMP protection. Replace
rtems_chain_extract() with rtems_chain_explicit_extract() and
rtems_chain_insert() with rtems_chain_explicit_insert() on SMP
configurations. Use rtems_chain_explicit_extract() and
rtems_chain_explicit_insert() to provide SMP support.
Add and use CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(),
RTEMS_CHAIN_INITIALIZER_ONE_NODE() and
RTEMS_CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN().
application visible API.
Move implementation specific parts of extension.h and extension.inl into
new header file extensionimpl.h. The extension.h contains now only the
