line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Create implementation header file.
Update #2555.
Update #2559.
This simplifies the RTEMS initialization and helps to avoid a memory
overhead. The workspace demands of the IO manager were not included in
the <rtems/confdefs.h> workspace size estimate. This is also fixed as a
side-effect.
Update documentation and move "Specifying Application Defined Device
Driver Table" to the section end. This sub-section is not that
important for the user. Mentioning this at the beginning may lead to
confusion.
This is the result of a sed script which converts all uses
of @{ into a consistent form.
http://www.google-melange.com/gci/task/view/google/gci2012/8032207
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
* libfs/src/devfs/devfs_mknod.c: Remove const cast.
* libfs/src/imfs/ioman.c: Remove const cast.
* libfs/src/devfs/devfs.h: Make device_name a const char*.
* sapi/include/rtems/io.h: Make device_name a const char*.
* cpukit/sapi/include/rtems/io.h: Documentation.
* cpukit/sapi/src/ioregisterdriver.c: Call from interrupt context is
an error.
* cpukit/sapi/src/iounregisterdriver.c: Disable preemption during
critical section.
* sapi/include/rtems/io.h, sapi/src/ioregisterdriver.c: Documenation.
rtems_io_lookup_name() is now deprecated. Added
rtems_io_driver_io_error(). rtems_io_register_driver() is now
thread-safe.
* sapi/include/rtems/extension.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c,
score/include/rtems/score/mpci.h, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h, score/src/coretod.c,
score/src/mpci.c, score/src/object.c, score/src/thread.c,
score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and
SuperCore Handler initialization routines to directly pull parameters
from configuration table.
reduce size of data area.
IMFS: Fixed creation of symbolic links to avoid a compiler warning.
DOSFS: Use LibBlock instead of read() to read the boot record.
* sapi/Makefile.am, sapi/include/rtems/io.h, sapi/src/io.c: Split into
one function per file execpt io.c which contains required
initialization methods.
* sapi/src/ioclose.c, sapi/src/iocontrol.c, sapi/src/iodata.c,
sapi/src/ioinitialize.c, sapi/src/ioopen.c, sapi/src/ioread.c,
sapi/src/ioregisterdriver.c, sapi/src/iounregisterdriver.c,
sapi/src/iowrite.c: New files.
* libmisc/Makefile.am, libmisc/monitor/mon-object.c,
libmisc/monitor/monitor.h, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/io.c: Eliminate maximum_drivers
configuration parameter since it was used to configure a no longer
used feature. Device names are now part of the filesystem not in a
table. This also eliminated the variables _IO_Number_of_devices and
_IO_Driver_name_table from RTEMS as well as the memory allocation
used to populate _IO_Driver_name_table.
* libmisc/monitor/mon-dname.c: Removed.
* sapi/include/rtems/io.h, sapi/src/io.c: Change rtems_io_register_name
to take a const char *.
* sapi/include/rtems/io.h : size_t device_name_length.
* sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/extension.h, sapi/include/rtems/fatal.h,
sapi/include/rtems/init.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/fatal.c,
sapi/src/io.c: Convert to using c99 fixed size types.
* include/confdefs.h, include/rtems/config.h,
include/rtems/extension.h, include/rtems/fatal.h,
include/rtems/init.h, include/rtems/io.h, include/rtems/mptables.h,
include/rtems/sptables.h, include/rtems/sptables.h.in,
inline/rtems/extension.inl, macros/rtems/extension.inl, src/debug.c,
src/exinit.c, src/extension.c, src/extensioncreate.c,
src/extensiondelete.c, src/extensionident.c, src/fatal.c, src/io.c,
src/itronapi.c, src/posixapi.c, src/rtemsapi.c: URL for license
changed.
PR 338/filesystem
* include/rtems/io.h, src/io.c: Side-effect of fixing reentrancy
problem with rtems_io_lookup_name() (API change).
* include/confdefs.h, include/rtems/config.h, include/rtems/io.h,
optman/no-io.c, src/exinit.c, src/io.c: Added a device driver
register/unregister interface to allow device drivers to be
installed and removed at runtime. This means you do not need devices
present in the device table when you build.
* include/rtems/io.h (rtems_driver_address_table): Added "_entry"
to all names.
* src/io.c: Accounted for above.
like signal dispatching.
+ variable length messages
+ named devices
+ debug monitor
