path: root/cpukit/sapi/ChangeLog (follow)
* 2001-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-241-0/+4
| | | | * optman/Makefile.am: Adapt ASM4FLAGS to automake-1.5.
* 2001-04-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2001-04-161-0/+4
| | | | * include/confdefs.h: Fix real-time clock support.
* 2001-02-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-02-051-0/+6
| | | | | | * include/Makefile.am, include/rtems/Makefile.am, inline/rtems/Makefile.am, macros/rtems/Makefile.am: Apply include_*HEADERS instead of H_FILES.
* 2001-01-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-291-0/+5
| | | | | * include/confdefs.h: define CONFIGURE_NEWLIB_EXTENSION 0 if not using NEWLIB, cleanup related comment.
* 2001-01-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-01-261-0/+4
| | | | * include/confdefs.h: include cpuopts.h, replace stubdr w/ devnull.
* 2000-10-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-311-0/+8
| | | | | | | | * POSIX include files merged into newlib. This resulted in some definitions moving to other files and thus some secondary effects in RTEMS source code. * include/confdefs.h: Replaced include of <sys/siginfo.h> with <signal.h> since that file no longer exists.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-0/+5
| | | | | * include/confdefs.h: Set CONFIGURE_INIT_TASK_STACK_SIZE to 0 if there is no Classic API Initialization Tasks Table defined.
* 2000-10-18 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-181-0/+6
| | | | | | * include/confdefs.h: Modified code that accounts for initialization task/threads with greater than minimum stack sizes so it would compile even if optional APIs are disabled.
* 2000-10-12 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-10-121-0/+5
| | | | | * include/confdefs.h: Account for initialization tasks and threads which use larger than minimum stack sizes.
* 2000-09-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2000-09-281-0/+6
| | | | | | * include/rtems/io.h (rtems_driver_address_table): Added "_entry" to all names. * src/io.c: Accounted for above.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+4
| | | | * src/Makefile.am, optman/Makefile.am: Include compile.am.
