Various tests must check program paths that result due to failed memory
allocations from the workspace. To avoid tinkering with internal
workspace structures throughout the test code these functions should be
used.
This PR was about a warning for no previous prototype for
rtems_interrupt_level_attribute. This method exists (like
a few others) to have real bodies for Classic API services
implemented as macros. These macros are not available from
anything but C and C++. The most explicit use was in the Ada
binding but these would be needed from assembly language
or any other non-C based language.
On top of needing a prototype, the methods were misnamed.
They were related to modes. This renames them, moves the
file, fixes test code, etc.
PR 1986/libcpu
* rtems/include/rtems/rtems/cache.h:
Add rtems_cache_aligned_malloc decl.
* rtems/src/rtemsobjectsetname.c:
Include <rtems/rtems/object.h> (Missing prototype).
* rtems/src/rtemsobjectgetclassicname.c:
* rtems/src/rtemsobjectgetname.c:
* rtems/src/rtemsobjectapiminimumclass.c:
Adjust rtems_object_api_minimum_class to prototype.
* rtems/src/workspace.c:
Include <rtems/rtems/support.h> (Missing prototypes).
* rtems/src/ratemonperiod.c: Make _Rate_monotonic_Update_statistics
static.
* rtems/src/rtemsobjectapimaximumclass.c:
Include <rtems/rtems/object.h> (Missing prototypes).
* sapi/src/exshutdown.c:
Include <rtems/init.h> (Missing prototypes).
* posix/include/rtems/posix/pthread.h:
Add _POSIX_Threads_Initialize_user_threads_body.
* rtems/include/rtems/rtems/tasks.h:
Add _RTEMS_tasks_Initialize_user_tasks_body.
* sapi/include/confdefs.h: Remove conditional, nested redeclaration of
_POSIX_Threads_Initialize_user_threads_body,
* rtems/src/tasks.c: Fix typos.
* rtems/src/taskinitusers.c: Fix typos.
* rtems/include/rtems/rtems/tasks.h: Typo fixes.
* rtems/src/tasks.c: Make _RTEMS_tasks_Create_extension,
_RTEMS_tasks_Start_extension, _RTEMS_tasks_Delete_extension,
_RTEMS_tasks_Switch_extension, _RTEMS_tasks_Post_switch_extension
static.
* score/src/scheduleredf.c: Make _Scheduler_EDF_RBTree_compare_function
static.
* rtems/include/rtems/rtems/event.h: Revert parameter name change.
* rtems/include/rtems/rtems/event.h,
rtems/include/rtems/rtems/eventset.h,
rtems/inline/rtems/rtems/eventset.inl: Documentation.
* rtems/Makefile.am: Add src/status.c.
* rtems/include/rtems/rtems/status.h: Make
_Status_Object_name_errors_to_status an external variable.
* rtems/src/status.c: New (split out from
rtems/include/rtems/rtems/status.h).
* rtems/Makefile.am: Reformat.
PR 1939/cpukit
* rtems/src/ratemonperiod.c: Fixed type mismatch.
* score/include/rtems/score/tod.h: Declare _TOD_Set_with_timestamp()
and _TOD_Get_as_timestamp().
* score/src/coretodset.c: Define _TOD_Set_with_timestamp().
* score/src/coretodget.c: Define _TOD_Get_as_timestamp().
* rtems/src/clockset.c: Use _TOD_Set_with_timestamp().
* score/include/rtems/score/timestamp64.h, score/src/ts64set.c:
Changed parameter types of _Timestamp64_Set().
* rtems/src/clocktodtoseconds.c: Year 2100 is not a leap year.
* rtems/include/rtems/rtems/clock.h, rtems/src/clockset.c: Added const
qualifier in rtems_clock_set().
PR 1916/testing
* rtems/src/ratemondelete.c, score/src/schedulercbsreleasejob.c,
score/src/scheduleredfupdate.c, score/src/scheduleredfyield.c: Rework
to improve coverage.
PR 1844/cpukit
* rtems/include/rtems/rtems/msgmp.h: Define
MESSAGE_QUEUE_MP_PACKET_SIZE.
* rtems/src/msgmp.c, rtems/src/msgqcreate.c: Use
* score/include/rtems/score/basedefs.h: Typo.
* score/src/mpci.c, rtems/src/eventmp.c, rtems/src/msgmp.c,
rtems/src/partmp.c, rtems/src/regionmp.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskmp.c: Use RTEMS_STATIC_ASSERT() to
ensure that the packet size is small enough.
PR 1895/cpukit
* rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, sapi/include/confdefs.h,
score/Makefile.am, score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/schedulersimple.h,
score/include/rtems/score/schedulersimplesmp.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/coremutexseize.c: Add priority_compare and release_job
hooks interfaces to scheduler interface.
* score/src/schedulerpriorityprioritycompare.c,
score/src/schedulerpriorityreleasejob.c: New files.
* rtems/include/rtems/rtems/tasks.h: Formatting.
* rtems/src/msgqcreate.c: Make packet size check consistent with
_Message_queue_MP_Send_request_packet().
* rtems/src/msgmp.c: Getting a remote object does not start a critical
section.
PR 1826/cpukit
* libmisc/cpuuse/cpuusagereport.c, rtems/Makefile.am,
rtems/preinstall.am, rtems/include/rtems.h: Add SMP Helper methods to
Classic API.
* rtems/include/rtems/rtems/smp.h: New file.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* rtems/include/rtems/rtems/tasks.h: Complete manager description.
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
PR 1819/cpukit
* rtems/src/clocktick.c, score/Makefile.am,
score/inline/rtems/score/scheduler.inl: Add a scheduler entry point
which is invoked at each clock tick. _Thread_Tickle_timeslice() is
now a method owned by the Deterministic Priority Scheduler and shared
by the Simple Priority Scheduler. The Simple SMP Scheduler has its
own variation on this which does timeslicing bookkeeping on all
cores.
* score/src/schedulerprioritytick.c,
score/src/schedulersimplesmptick.c: New files.
* score/src/threadtickletimeslice.c: Removed.
* rtems/src/taskresume.c, score/Makefile.am,
score/include/rtems/score/thread.h: Convert _Thread_Resume and
_Thread_Suspend into macros.
* score/src/threadresume.c, score/src/threadsuspend.c: Removed.
* rtems/inline/rtems/rtems/attr.inl,
rtems/inline/rtems/rtems/eventset.inl,
rtems/inline/rtems/rtems/options.inl: Add missing includes.
* rtems/inline/rtems/rtems/status.inl: Add missing include.
* rtems/src/semtranslatereturncode.c,
score/include/rtems/score/coremutex.h: Returns tests to running
state.
* rtems/src/semtranslatereturncode.c, score/src/coremutexsurrender.c:
Now all conditionals have the correct sense and all tests pass.
score/src/coremutexsurrender.c,
score/src/objectinitializeinformation.c: Disable code not reachable
when POSIX is not enabled.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/inline/rtems/score/schedulerpriority.inl: New files.
* rtems/src/ratemonreportstatistics.c, rtems/src/ratemonresetall.c:
Remove unchecked return status pointed out by clang.
* rtems/Makefile.am, rtems/preinstall.am: Install
<rtems/rtems/mainpage.h> to allow documentation generation.
* rtems/include/rtems.h, rtems/mainpage.h,
rtems/include/rtems/rtems/types.h: Documentation.
