* src/msgqsubmit.c: Add a comment indicating that we do not have
to account for possibly blocking during the core send operation
because Classic API message queue send is always non-blocking.
* src/msgqsubmit.c: Unblocking message queue operations should
by Suvrat Gupta <suvrat@utstar.com>.
* src/eventsurrender.c: Clear event condition when task is unblocked.
This makes sure that subsequent event send thinks the task is still
blocked and overwrites the initial events received.
* include/Makefile.am, include/rtems/rtems/Makefile.am,
inline/rtems/rtems/Makefile.am, macros/rtems/rtems/Makefile.am,
rtems/optman/Makefile.am:
* include/rtems.h, src/signalcatch.c: Modifications to make
CodeWarrior happy.
* src/regiongetinfo.c: Removed unused variable to eliminate warning.
* src/msgqsubmit.c: Modified multiprocessing conditional so
this would compile with both macros and inlines.
* macros/rtems/rtems/sem.inl: Added macro implementation of
_Semaphore_Get_interrupt_disable().
* src/regiongetinfo.c, include/rtems/rtems/region.h,
include/rtems/rtems/types.h, src/Makefile.am: Added
region_get_information() and information control block.
* src/regiongetinfo.c: New file.
* include/rtems/rtems/ratemon.h, src/ratemonperiod.c,
src/ratemontimeout.c: Add next_length field so period length
can be changed by the the sequence period(X), period(not X)
with no intervening cancel or expiration.
* optman/Makefile.am, src/Makefile.am: Include compile.am.
* taskstart.c: Removed 1st cut at rtems_task_start_main_style.
Only committed this so it could be easily revisited as we
discussing moving main() to user space from BSP space.
* taskstart.c: Added 1st cut at rtems_task_start_main_style.
semaphore/mutex can be obtained immediately, this cuts execution time
by 50%.
names to be rtems_PACKAGE_method.
by the network build.
significant things:
and PowerPC
same code base.
that contains:
* Removes MKLIB
handling)
<andrew@pogo.wv.tek.com>.
Eric Norum <eric@cls.usask.ca>.
I'd like to propose a change to RTEMS task variables that I think would
make them more useful. I think that it is early enough in their
existence to still make changes to their API.
1) Change type from `int' to `void *'.
2) Add extra argument to task_variable_add -- if non-NULL, a pointer to
a `destructor' function to be called when the task exits. This function
would be called with that task's value of the task variable as its
argument. In many cases, the `dtor' function could be `free'.
rtems_status_code rtems_task_variable_add (
rtems_id tid, void **ptr, void (*dtor)(void *));
rtems_status_code rtems_task_variable_delete (rtems_id tid, void **ptr);
This would be all we'd need to cleanly and efficiently support C++
per-thread exception information without dragging in all that POSIX API
stuff.
were done by Joel.
and his EPICS porting effort.
Addtional major bugs:
*.cfg files.
dependencies
automake and RTEMS make rules
convention)
performs automatically.
WARNING:
Makefile.ams.
RTEMS API extension to avoid problems when the extension is freed.
Eventually the task variable switch extension should become part
of the core context switch and the Ada tcb self implemented in
terms of it.
it is now typedef'ed.
just "rtems_task_variable_t".
task_variables field to API extension, and two directives
(rtems_task_variable_add and rtems_task_variable_delete).
After being submitted, this support was rewritten to be inside the
executive rather than layered on top of it using an extension.
