argument indicates whether the task is to be placed at the head or tail of
its priority fifo when it is lowering its own priority. POSIX normally
follows the RTEMS API conventions but GNAT expects that all lowering of
a task's priority by the task itself will result in being placed at the
head of the priority FIFO. Normally, this would only occur as the result
of lose of inherited priority.
The RTEMS API always puts tasks at the end of their priority group except
upon loss of inherited priority.
he received using the Microtec C++ compiler. Most of these are
either missing casts from/to (void *), heavy handed use of enumerated
types, or simply assumed conversions. There is at least one actual
bug in an error path in thread.c in which the wrong argument was
passed to _Thread_Stack_Free and was not being caught by gcc.
in the core to support multiple algorithms to handle cpu time budgetting
which resulted in a change to the calling sequence of _Thread_Initialize.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
create POSIX initialization threads.
sem.c: modified to eliminate Purify warnings
support.h: updated to use RTEMS_APPLICATION macro
in each thread which must be set when the post switch extension is to be run.
are automatically activated upon insertion.
possible synchronization actions. This should have made it harder to
avoid a case.
Replaced critical section algorithm to correct race conditions.
This resulted in the new variable _Event_Sync_state and the type
_Event_Sync_states.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
