in the core to support multiple algorithms to handle cpu time budgetting
which resulted in a change to the calling sequence of _Thread_Initialize.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
create POSIX initialization threads.
sem.c: modified to eliminate Purify warnings
support.h: updated to use RTEMS_APPLICATION macro
in each thread which must be set when the post switch extension is to be run.
are automatically activated upon insertion.
possible synchronization actions. This should have made it harder to
avoid a case.
Replaced critical section algorithm to correct race conditions.
This resulted in the new variable _Event_Sync_state and the type
_Event_Sync_states.
like signal dispatching.
correct Information block.
+ Added name pointer to Object_Control.
+ Modified Object Open and Close to address name field.
+ Removed name as separate element from Thread and Proxy Control.
+ Added parameter "object class" to calls to Initialize Information
+ variable length messages
+ named devices
+ debug monitor
blocking mechanism for it.
