This patch fixes bug #4403. Directives
* rtems_timer_fire_when()
* rtems_timer_server_fire_when()
* rtems_task_wake_when()
are documented to return RTEMS_INVALID_ADDRESS when their time-of-day
argument is NULL. But actually they return RTEMS_INVALID_CLOCK. To fix
the issue this patch changes _TOD_Validate() to return a
status code instead of just true/false.
Close #4403
Use _Objects_Free_nothing() for rtems_message_queue_construct() to avoid
unreachable code in _CORE_message_queue_Close() in case only
user-provided message buffers are used.
Update #4007.
Rename _Stack_Free_nothing() in _Objects_Free_nothing() to make it
reusable for the message queue buffers.
Update #4007.
In case the processor set is not large enough to contain the processor
set owned by the scheduler return RTEMS_INVALID_SIZE instead of
RTEMS_INVALID_NUMBER. This is more in line with other directives since
the issue is related to the size of an object.
Close #4401.
Check for a NULL processor set pointer.
The allocator mutex is recursive and already used for the task creation
in rtems_timer_initiate_server(). Just use this mutex instead of the
once mutex to serialize the initialization. This avoids a dependency on
condition variables which are not used here.
The __builtin_unreachable() cannot be used with current GCC versions to
tell the compiler that a function does not return to the caller, see:
https://gcc.gnu.org/bugzilla/show_bug.cgi?id=99151
Add a no return variant of _Thread_Dispatch_direct() to avoid generation
of dead code.
This may reduce the code size a bit.
This avoids having conditional statements to get the API-specific status
code.
code.
There is no need to disable thread dispatching to get the affinity of a
task.
code.
Close #4392.
Since there are already excessive NULL pointer checks in the Classic
API, do this also in rtems_task_construct().
Update #3959.
API, do this also in rtems_message_queue_construct().
Update #4007.
This patch fixes issue #4338 by changing _TOD_Validate()
to only accept years till 2105. This requires another patch
to change the documentation of rtems_clock_set() and other
affected API functions (indicating the end date is 2105 not 2514).
I tried to support till year 2514 but it turned out that
this needs changing the Timer Manager too. That in turn
would mean to change _TOD_Seconds_since_epoch( void )
from 32 to 64 bit. Sebastian pointed out that a naive extension
leads to trouble with 32 bit processors. He deemed a safe
re-implementation too costly performance wise considering
that year 2106 is far away and current binaries using RTEMS
Classic API are unlikely to be in use by 2106.
The constant TOD_SECONDS_AT_2100_03_01_00_00 in
cpukit/rtems/src/clocktodtoseconds.c happens to be wrong by
1 hour. When setting the date 2100-Feb-28 23:59:59 and then
reading the date again you will find yourself in 2100-Feb-27.
Update #4338
Replace Objects_Name_or_id_lookup_errors with new Status_Control codes.
Get rid of the _Status_Object_name_errors_to_status lookup table.
The value of STATUS_CLASSIC_INTERNAL_ERROR must be equal to
RTEMS_INTERNAL_ERROR. Add static assertions to ensure that the status
codes match.
Check only for invalid modes if a valid handler is presented to
rtems_signal_catch(). When NULL is used for the handler, ASR processing
is disabled and the mode is not used.
Update #4244.
Do the ASR and preemption mode change only if requested by the mode
mask. The bug was introduced by
508f868237225a75e566d9fd304206363cfe441d.
Do not mix checks for different error indicators (RTEMS_NOT_DEFINED and
RTEMS_INVALID_NUMBER). This simplifies the specification of
rtems_semaphore_create().
MrsP semaphores are a generalization of the priority ceiling semaphores
for SMP configurations. Priority ceiling semaphores are required to use
the priority task wait queue discipline. Require this discipline also
for MrsP semaphores.
Close #4347.
In uniprocessor configurations, we can simplify rtems_signal_catch().
Add a validation test for the SMP special case.
Use the invariant that an ASR is only processed if ASR processing is
enabled.
Close the thread object if a thread create extension fails. Also call
the delete extension to avoid resource leaks in early extensions if a
late extension fails.
Close #4270.
Use the number of threads which must arrive at the barrier to trip the
automatic release also to indicate if the barrier is a manual release
barrier.
Use the type safe _Objects_Open_u32() instead. Return the object
identifier to enforce a common usage pattern.
Do the preemption and ASR processing changes in one rush and acquire the
thread state lock only once.
Do the mode changes necessary for the ASR processing directly under
protection of the thread state lock to avoid the recursive calls to
thread dispatching done in rtems_task_mode().
Close #4244.
Update #4244.
Ensure that no invalid modes are set during ASR processing.
Update #4244.
This call just obfuscated the call to _ISR_Set_level().
Update #4244.
Remove superfluous ASR_Information::signals_posted. Move code out of
trivial inline functions.
Update #4244.
Move _Signal_Action_handler() and signal MP initialization to
rtems_signal_send(). The goal is to make _Signal_Action_handler() a
static function in a follow up patch.
Update #4244.
Update #4244.
Require that the corresponding lock is acquired before the action
handler returns. This helps to avoid recursion in the signal
processing.
Update #4244.
- Move the heap sbrk code into a separate routnine.
- Update heap and workspace greedy allocators to use the common
sbrk greedy support.
Closes #3982
Use the rtems_clock_get_ticks_per_second() macro to implement the
rtems_clock_get_ticks_per_second() function.
Add a "Constraints" paragraph to the documentation.
Provide prototypes for programming language bindings. Use the macro
implementation to implement the corresponding functions.
Update #3993.
This fix relates to a Coverity issue (UNUSED_VALUE).
We do not need all the checks if we have a valid indentifier to a thread
class object.
Using the new _Thread_Get_objects_information() instead of the inline
function _Thread_Get_objects_information_by_id() avoids dead code since
the identifier in a thread control is always valid and the return NULL
path in _Thread_Get_objects_information_by_id() would be dead code. The
_Thread_Get_objects_information_by_id() should be an inline function
since it is used by _Thread_Get() and thus performance critical. Static
analyzers which cannot derive that the identifier in a thread control is
always valid, may find a potential NULL pointer access (or otherwise
find dead code).
The identifier in an object control is always valid, see
_Objects_Initialize_information() and _Objects_Extend_information().
Move _RTEMS_tasks_Free() to the only source file which calls this
function.
This fixes implicit conversions between different enum types.
Return RTEMS_NO_MEMORY if there is not memory available to duplicate the
name.
Use common phrases for the file brief descriptions.
Update #3706.
Rename Classic API top-level group from Classic to RTEMSImplClassic.
Use RTEMSImplClassic as a prefix for the subgroups. Change the group
names to be in line with the API group names. Use common phrases for
the group brief descriptions.
Update #3706.
In order to better support applications which use the new
rtems_task_construct() directive add the
CONFIGURE_INIT_TASK_CONSTURCT_STORAGE_SIZE configuration option. If
this option is specified, then the Classic API initialization task is
constructed with rtems_task_construct().
Update #4181.
Replace a runtime check with a compile time assertion. This makes the
INTERNAL_ERROR_RTEMS_INIT_TASK_ENTRY_IS_NULL obsolete.
Update #4181.
